Environment:
- Hardware: Jetson AGX Orin Developer Kit
- L4T Version: R36.4.3
- Flash Method: l4t_initrd_flash.sh with external NVMe
Problem:
After successful flash completion, device fails to boot from NVMe. Serial console shows:
[ 29.328034] ERROR: mounting PARTUUID=4934d836-4f19-4da5-8758-f88b3c9e088d as /mnt fail…
[ 29.329409] ERROR: PARTUUID=4934d836-4f19-4da5-8758-f88b3c9e088d mount fail…
flashing command:
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c tools/kernel_flash/flash_l4t_t234_nvme.xml --showlogs --network usb0 jetson-agx-orin-devkit external
flash finish log:
Writing qspi_bootblob_ver.txt (parittion: A_VER) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/qspi_bootblob_ver.txt
Writing /mnt/internal/qspi_bootblob_ver.txt (109 bytes) into /dev/mtd0:66977792
Copied 109 bytes from /mnt/internal/qspi_bootblob_ver.txt to address 0x03fe0000 in flash
Writing gpt_secondary_3_0.bin (parittion: secondary_gpt) into /dev/mtd0
Sha1 checksum matched for /mnt/internal/gpt_secondary_3_0.bin
Writing /mnt/internal/gpt_secondary_3_0.bin (16896 bytes) into /dev/mtd0:67091968
Copied 16896 bytes from /mnt/internal/gpt_secondary_3_0.bin to address 0x03ffbe00 in flash
[ 226]: l4t_flash_from_kernel: Successfully flash the qspi
writing item=17, 9:0:secondary_gpt, 61203267072, 16896, gpt_secondary_9_0.bin, 16896, fixed–0, ef3783b4a8758c0ba89a9927ee6a3271d7558ad0
[ 655]: l4t_flash_from_kernel: Successfully flash the external device
[ 655]: l4t_flash_from_kernel: Flashing success
[ 655]: l4t_flash_from_kernel: The device size indicated in the partition layout xml is smaller than the actual size. This utility will try to fix the GPT.
Flash is successful
Reboot device
Cleaning up…
Log is saved to Linux_for_Tegra/initrdlog/flash_3-6.2_0_20260603-103800.log
