When I add a new stream that is not open by restful api, that stream that is not open, this will cause that all pipeline quit
• Hardware Platform (Jetson / GPU) Jetson AGX
• DeepStream Version 7.0
**• JetPack Version (valid for Jetson only) 6.0 GA
**• TensorRT Version 8.6
**• NVIDIA GPU Driver Version (valid for GPU only) 540.3.0
**• Issue Type( questions, new requirements, bugs) questions
with deepstream-test5-app When I add a new stream that is not open by restful api, that stream that is not open, this will cause that all pipeline quit
about “When I add a new stream that is not open by restful api” , do you mean you only set some rtsp uri in the configuration file? could you share the configuration file of test5?
No , I use restful api to add stream, like below
curl -XPOST ‘http://localhost:40257/api/v1/stream/add’ -d ‘{
“key”: “sensor”,
“value”: {
“camera_id”: “303239333436003d15ab4eb5165a0001”,
“camera_name”: “hik”,
“camera_url”: “rtsp://admin:a12345678@192.168.31.9/Streaming/Channels/1”,
“change”: “camera_add”,
but this camera_url can not be opened.
for example, I used restful api to add 4 streams , because previous 4 streams can be opened.
When I add the 5th stream like above ,but this camera_url can not be opened.
The program quit. previous 4 streams are also down
  1. my test is fine. please refer to log-0722.txt (554 Bytes).
  2. could you share more log 1.log by the following steps?
export GST_DEBUG=6
"start app"  >1.log 2>1.log
  1. from the logs you shared, it should be related to RTSP. can this pipeline work?
gst-launch-1.0 rtspsrc location=rtsp://admin:a12345678@192.168.31.9/Streaming/Channels/1  ! fakesink
Did you understand what I said?
1、、for example, I used restful api to add 4 streams , because previous 4 streams can be opened. This is success.
2、When I add the 5th stream like above ,but this camera_url can not be opened. The program quit. previous 4 streams added are also down.
I want to explain that the 5th stream that can not be opened let previous 4 streams added down
  1. Could you share more log mentioned in my last comment? Thanks.
  2. Can the camera support 5 connections?you can use the gst-launch command-line in my last comment to test.
answer :
1、The picture above showed error message.
2、don.t support. The 5 streams are not from the same camera.
Test Scenario
1、With deepstream-test5-app,you can use restful api adding 2 , 3, or 4 streams, ( The streams are not from the same camera). The pipeline is normal.
2、 you can add next stream (this stream is abnormal), you can see the log of deepstream-test5-app.
I want to ask this question , when you add an abnormal stream to a normal pipeline, whether deepstream-test5-app is down? In other words,whether the next stream(this stream is abnormal) being adding let a normal pipeline down? Can you understand what I said?
it depends on what kind of abnormal stream. I tested with an invalid stream, and can’t reproduce the quit issue. here is the log log-0723.txt (1.6 KB). it is related with the error “No supported authentication protocol was found”. this error message will be passed to bus_callback. deepstream-test5 code is opensource. you can add custom code in
bus_callback of opt\nvidia\deepstream\deepstream-7.0\sources\apps\sample_apps\deepstream-app\deepstream_app.c. for example, you can make the app not quit after getting this error message in bus_callback.
log.txt (4.3 MB)
The log is like this
This is all message
ERROR from src: Internal data stream error.
Debug info: …/g
the log above is printed in bus_callback. then the app will quit because of “appCtx->quit = TRUE;”. you can make the app not quit after getting some specific error.
So this pipeline support n streams, if one stream recevice eos message , others will be abnormal?
no, one stream EOS will not affect the other streams. after all streams EOS, the application will quit.
