When I added the following contents, the device was repeatedly booted in the boot logo, and the system could not be accessed
Dear all:
  1. Jetpack4.6_R32.6.1, jetson tx2 nx SOM in our custom board.
  2. After add following content in tegra186-p3636-0001-common.dtsi file, device get wrong.
    Continuing the discussion from TX2 NX SPI pinmux setting on R32.6.1 error:
+       pinmux@2430000 {
+               pinctrl-0 = <0x179>;
+               pinctrl-names = "default";
+               compatible = "nvidia,tegra194-pinmux";
+               reg = <0x0 0x2430000 0x0 0x17000 0x0 0xc300000 0x0 0x4000>;
+               #gpio-range-cells = <0x3>;
+               status = "okay";
+               linux,phandle = <0xab>;
+               phandle = <0xab>;
+               header-40pin-pinmux {
+                       phandle = <0x179>;
+                       linux,phandle = <0x179>;
+                       pin24 {
+                               nvidia,lpdr = <0x0>;
+                               nvidia,enable-input = <0x1>;
+                               nvidia,tristate = <0x0>;
+                               nvidia,pull = <0x2>;
+                               nvidia,pins = "spi1_cs0_pz6";
+                               nvidia,function = "spi1";
+                       pin23 {
+                               nvidia,pull = <0x1>;
+                               nvidia,pins = "spi1_sck_pz3";
+                       pin21 {
+                               nvidia,pins = "spi1_miso_pz4";
+                       pin19 {
+                               nvidia,pins = "spi1_mosi_pz5";
+       can_clock: can_clock {
+               compatible = "fixed-clock";
+               #clock-cells = <0>;
+               clock-frequency = <8000000>;
+               clock-accuracy = <100>;
        spi@3210000 { /* SPI 1 to 40 pin header */
                status = "okay";
                spi@0 {
-                       compatible = "tegra-spidev";
+                       compatible = "microchip,mcp2515";
                        reg = <0x0>;
-                       spi-max-frequency = <33000000>;
+                        spi-max-frequency = <5000000>;
+                        clocks = <&can_clock>;
+                        interrupt-parent = <&tegra_main_gpio>;
+                       interrupts = <&tegra_main_gpio TEGRA_MAIN_GPIO(N, 1) GPIO_ACTIVE_HIGH>;
                        controller-data {
                                nvidia,enable-hw-based-cs;
                                nvidia,rx-clk-tap-delay = <0x8>;
You may need UART log to check the kernel message to know the root cause.
After change tegra186-mb1-bct-pinmux-p3636-0001-a00.cfg as following, i can see can1. but can1 only can receive ,can not send data.
this is dmesg follow, gpio set failed.
1667985760241
What’s the pin 22/23? Doesn’t see your dts change relative with GPIO.
sudo /opt/nvidia/jetson-io/jetson-io.py , this gpio is define by nvidia.
1668062799207
Did you add those SPI pin configuration manually or that’s generate from jetson-io?
I change this pinmux in following picture.
Please use jetson-io to configure the PINs for TX2 NX
After execute sudo /opt/nvidia/jetson-io/jetson-io.py and enable spi1, device can not enter system , just restart in boot logo.
OK, will try if able catch the problem like you do.
There is a known issue in cboot that may cause jetson IO fails to take effect.
