When I try to install anything that matters to run code (thonny, etc), I get many errors. I flash the same is using same flasher (rufus) and different internal packages are broken each time. It’s like a slot machine of errors.
Hi, please attach the error log here (as text, not image).
We cannot help you with such vague information.
Also, to make sure, you are using a Jetson Nano board right?
What version of L4T is installed? The latest r32.7.3?
Here’s the errorE: Sub-process /usr/bin/dpkg returned an error code (2)
L4T is R32 revision 7.1
Try this post and see if it helps:
Did you fail to install any packages with APT before getting these errors and after doing a whole re-flash?
I tried that but trying sudo apt-get install python-pip
returns the same error. Also, what do you mean “doing a whole-reflash”?
Can you follow this guide:
https://docs.nvidia.com/jetson/archives/l4t-archived/l4t-3261/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/quick_start.html#
, or use SDK Manager to flash your device?
