The error code is -301 or -500, what does the error code mean? could you provide a complete error list?Thanks.
Now only the following error codes are provided:
typedef enum NvCV_Status {
NVCV_SUCCESS = 0, //!< The procedure returned successfully.
NVCV_ERR_GENERAL = -1, //!< An otherwise unspecified error has occurred.
NVCV_ERR_UNIMPLEMENTED = -2, //!< The requested feature is not yet implemented.
NVCV_ERR_MEMORY = -3, //!< There is not enough memory for the requested operation.
NVCV_ERR_EFFECT = -4, //!< An invalid effect handle has been supplied.
NVCV_ERR_SELECTOR = -5, //!< The given parameter selector is not valid in this effect filter.
NVCV_ERR_BUFFER = -6, //!< An image buffer has not been specified.
NVCV_ERR_PARAMETER = -7, //!< An invalid parameter value has been supplied for this effect+selector.
NVCV_ERR_MISMATCH = -8, //!< Some parameters are not appropriately matched.
NVCV_ERR_PIXELFORMAT = -9, //!< The specified pixel format is not accommodated.
NVCV_ERR_MODEL = -10, //!< Error while loading the TRT model.
NVCV_ERR_LIBRARY = -11, //!< Error loading the dynamic library.
NVCV_ERR_INITIALIZATION = -12, //!< The effect has not been properly initialized.
NVCV_ERR_FILE = -13, //!< The file could not be found.
NVCV_ERR_FEATURENOTFOUND = -14, //!< The requested feature was not found
NVCV_ERR_MISSINGINPUT = -15, //!< A required parameter was not set
NVCV_ERR_RESOLUTION = -16, //!< The specified image resolution is not supported.
NVCV_ERR_UNSUPPORTEDGPU = -17, //!< The GPU is not supported
NVCV_ERR_WRONGGPU = -18, //!< The current GPU is not the one selected.
NVCV_ERR_UNSUPPORTEDDRIVER = -19, //!< The currently installed graphics driver is not supported
NVCV_ERR_MODELDEPENDENCIES = -20, //!< There is no model with dependencies that match this system
NVCV_ERR_PARSE = -21, //!< There has been a parsing or syntax error while reading a file
NVCV_ERR_MODELSUBSTITUTION = -22, //!< The specified model does not exist and has been substituted.
NVCV_ERR_READ = -23, //!< An error occurred while reading a file.
NVCV_ERR_WRITE = -24, //!< An error occurred while writing a file.
NVCV_ERR_PARAMREADONLY = -25, //!< The selected parameter is read-only.
NVCV_ERR_TRT_ENQUEUE = -26, //!< TensorRT enqueue failed.
NVCV_ERR_TRT_BINDINGS = -27, //!< Unexpected TensorRT bindings.
NVCV_ERR_TRT_CONTEXT = -28, //!< An error occurred while creating a TensorRT context.
NVCV_ERR_TRT_INFER = -29, ///< The was a problem creating the inference engine.
NVCV_ERR_TRT_ENGINE = -30, ///< There was a problem deserializing the inference runtime engine.
NVCV_ERR_NPP = -31, //!< An error has occurred in the NPP library.
NVCV_ERR_CONFIG = -32, //!< No suitable model exists for the specified parameter configuration.
NVCV_ERR_TOOSMALL = -33, //!< A supplied parameter or buffer is not large enough.
NVCV_ERR_TOOBIG = -34, //!< A supplied parameter is too big.
NVCV_ERR_WRONGSIZE = -35, //!< A supplied parameter is not the expected size.
NVCV_ERR_OBJECTNOTFOUND = -36, //!< The specified object was not found.
NVCV_ERR_SINGULAR = -37, //!< A mathematical singularity has been encountered.
NVCV_ERR_NOTHINGRENDERED = -38, //!< Nothing was rendered in the specified region.
NVCV_ERR_OPENGL = -98, //!< An OpenGL error has occurred.
NVCV_ERR_DIRECT3D = -99, //!< A Direct3D error has occurred.
NVCV_ERR_CUDA_BASE = -100, //!< CUDA errors are offset from this value.
NVCV_ERR_CUDA_VALUE = -101, //!< A CUDA parameter is not within the acceptable range.
NVCV_ERR_CUDA_MEMORY = -102, //!< There is not enough CUDA memory for the requested operation.
NVCV_ERR_CUDA_PITCH = -112, //!< A CUDA pitch is not within the acceptable range.
NVCV_ERR_CUDA_INIT = -127, //!< The CUDA driver and runtime could not be initialized.
NVCV_ERR_CUDA_LAUNCH = -819, //!< The CUDA kernel launch has failed.
NVCV_ERR_CUDA_KERNEL = -309, //!< No suitable kernel image is available for the device.
NVCV_ERR_CUDA_DRIVER = -135, //!< The installed NVIDIA CUDA driver is older than the CUDA runtime library.
NVCV_ERR_CUDA_UNSUPPORTED = -901, //!< The CUDA operation is not supported on the current system or device.
NVCV_ERR_CUDA_ILLEGAL_ADDRESS = -800, //!< CUDA tried to load or store on an invalid memory address.
NVCV_ERR_CUDA = -1099, //!< An otherwise unspecified CUDA error has been reported.
} NvCV_Status;
