hi:
tegra186-quill-common.dtsi:24:41: fatal error: panels/panel-s-wuxga-8-0.dtsi
I searched the dir , the vesrion is l4t-r28.1, indeed it has not the file
hi:
I’m not familiar with “panels/panel-s-quxga-8-0.dtsi” but I will try help… You will need to provide more information, such as:
If you are looking for panel-s-quxga-8-0.dtsi, it is located (in mine L4T Kernel 4.4):
You might find it is a relative path to directories just below the kernel. Try downloading your kernel source via the “source_sync.sh” script in the “Linux_for_Tegra/” subdirectory of the driver package:
./source_sync.sh -k tegra-l4t-r28.2
(adjust for release if not using R28.2)
