error :corrupted size vs. prev_size while consolidating Aborted (core dumped)
mycode:
static GstPadProbeReturn
nvinfer_src_pad_buffer_probe1 (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj = NULL;
NvDsObjectMeta *obj_meta = NULL;
// Get original raw data
GstMapInfo in_map_info;
if (!gst_buffer_map (buf, &in_map_info, GST_MAP_READ)) {
g_print (“Error: Failed to map gst buffer\n”);
gst_buffer_unmap (buf, &in_map_info);
return GST_PAD_PROBE_OK;
char* src_data = NULL;
NvBufSurface *surface = (NvBufSurface *)in_map_info.data;
int conunt=0;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next)
//图像转换
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
if (!frame_meta)
continue;
guint height = surface->surfaceList[frame_meta->batch_id].height;
guint width = surface->surfaceList[frame_meta->batch_id].width;
cudaMalloc((void**)&src_data,surface->surfaceList[frame_meta->batch_id].dataSize);
cudaMemcpy((void*)src_data,(void*)surface->surfaceList[frame_meta->batch_id].dataPtr,surface->surfaceList[frame_meta->batch_id].dataSize,cudaMemcpyDeviceToDevice);
cv::cuda::GpuMat nv12_mat=cv::cuda::GpuMat(height, width, CV_8UC4, src_data,surface->surfaceList[frame_meta->batch_id].pitch);
cv::cuda::GpuMat nv12_mat_out=cv::cuda::GpuMat(height, width, CV_8UC4);
cv::cuda::resize(nv12_mat, nv12_mat, cv::Size(512,512 ));
cv::Rect area_new = cv::Rect(512, 0,512, 512);
nv12_mat.copyTo(nv12_mat_out(area_new));
cudaMemcpy((void*)surface->surfaceList[frame_meta->batch_id].dataPtr,(void*)nv12_mat_out.data,surface->surfaceList[frame_meta->batch_id].dataSize,cudaMemcpyDeviceToDevice);
//cv::Mat cpu_Mat;
// nv12_mat_out.download(cpu_Mat);
if(src_data != NULL)
cudaFree(src_data);
src_data = NULL;
//图像转换 ---
//渲染的设置
NvDsDisplayMeta *disp_meta = NULL;
if (!disp_meta) {
disp_meta = nvds_acquire_display_meta_from_pool(batch_meta);
disp_meta->num_lines = 0;
} //申请空间
//首先画一个固定的框图 限定一个区域
disp_meta->line_params[disp_meta->num_lines].x1 =0;
disp_meta->line_params[disp_meta->num_lines].y1 =0;
disp_meta->line_params[disp_meta->num_lines].x2 =512;
disp_meta->line_params[disp_meta->num_lines].y2 =0;
disp_meta->line_params[disp_meta->num_lines].line_width = 4;
disp_meta->line_params[disp_meta->num_lines].line_color.red = 1.0;
disp_meta->line_params[disp_meta->num_lines].line_color.green = 0.0;
disp_meta->line_params[disp_meta->num_lines].line_color.blue = 0.0;
disp_meta->line_params[disp_meta->num_lines].line_color.alpha = 0.5;
disp_meta->num_lines=disp_meta->num_lines+1;
disp_meta->line_params[disp_meta->num_lines].x2 =0;
disp_meta->line_params[disp_meta->num_lines].y2 =512;
disp_meta->line_params[disp_meta->num_lines].x1 =512;
disp_meta->line_params[disp_meta->num_lines].y1 =512;
for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;l_obj = l_obj->next)
obj_meta = (NvDsObjectMeta *) (l_obj->data);
if (!obj_meta)
continue;
for (NvDsMetaList * l_user = obj_meta->obj_user_meta_list; l_user != NULL;
l_user = l_user->next)
NvDsUserMeta *user_meta = (NvDsUserMeta *)l_user->data;
if(user_meta->base_meta.meta_type == (NvDsMetaType) NVDS_USER_JARVIS_META_PYVA)
NvDsPyvaMetaData *PYVA_meta =
(NvDsPyvaMetaData *) user_meta->user_meta_data;
conunt=conunt+1;
//大致的渲染结果
float x_center=PYVA_meta->x_center;
float y_center=PYVA_meta->y_center;
float width=PYVA_meta->width; //0
float height=PYVA_meta->height;//1
float xtl=256-(y_center-height/2)/80*512;//x0
float ytl=341-(x_center-width/2)/120*512;//y0
float xbr=256-(y_center+ width/2)/80*512;//x3
float ybr=341-(x_center+height/2)/120*512;//y3
float rect_width=xbr-xtl;
float rect_height=ybr-ytl;
float x1=xtl+rect_width/2;
float y1=ytl;
float x2=xtl;
float y2=ytl+rect_height/2;
disp_meta->line_params[disp_meta->num_lines].x2 =100;
disp_meta->line_params[disp_meta->num_lines].line_color.red = 0.0;
disp_meta->line_params[disp_meta->num_lines].line_color.blue = 1.0;
disp_meta->line_params[disp_meta->num_lines].x1 =100;
disp_meta->line_params[disp_meta->num_lines].y2 =100;
disp_meta->line_params[disp_meta->num_lines].y1 =100;
if(disp_meta)
nvds_add_display_meta_to_frame (frame_meta, disp_meta);
