When I run “import tensorrt”, I got ImportError: libnvdla_compiler.so: cannot open shared object file: No such file or directory
And I found that I did not have /usr/lib/aarch64-linux-gnu/tegra/. Where I can got this file, with tensorrt version 8.5.2.2?
Which OS branch are you using?
Do you use r35.3.1 from JetPack 5.1.1?
I think it is r34.1.1. But I am not sure how to check the version of OS branch XD.
You can check it with the following command:
$ cat /etc/nv_tegra_release
The library can be found on r35.3.1 release:
$ sudo find / -iname libnvdla_compiler.so
/usr/lib/aarch64-linux-gnu/tegra/libnvdla_compiler.so
Thank you for your reply. I think it is due to the installation issue. I gave ip python and turn to C++ XD. But I met another problem, I found there is no nvidia-smi
in orin. So how can I monitor the GPU in orin?
nvidia-smi
is a discrete GPU tool (the desktop GPU).
On Jetson, you can check the system status with tegrastats
$ sudo tegrastats
