2024-09-26 11:13:44 [16,130ms] [Error] [gpu.foundation.plugin] CUDA interop cannot be used!
2024-09-26 11:13:44 [16,130ms] [Error] [gpu.foundation.plugin] Texture creation failed for the device: 0.
2024-09-26 11:13:44 [16,130ms] [Error] [carb.scenerenderer-rtx.plugin] Failed to allocate 1280x720 LdrColor resource for device mask 0x1
2024-09-26 11:13:44 [16,132ms] [Error] [carb.events.python] TypeError: set_image_data(): incompatible function arguments. The following argument types are supported:
1. (self: omni.ui._ui.ImageProvider, arg0: capsule, arg1: int, arg2: int, arg3: omni.gpu_foundation_factory._gpu_foundation_factory.TextureFormat) → None
2. (self: omni.ui._ui.ImageProvider, rp_resource: omni.gpu_foundation_factory._gpu_foundation_factory.RpResource, presentation_key: int = 0) → None
I recommend upgrading to the latest version of Isaac Sim, which is currently 4.2.0. This version was released in this month and is the recommended distribution. Thanks.
