When I open the usd file, isaac sim doesn't work
[9.773s] Isaac Sim App is loaded.
2024-05-25 08:04:54 [14,789ms] [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource '/home/syh/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/exts/omni.kit.window.filepicker/icons/ov_logo.png:2024-01-25@17:23:25'
2024-05-25 08:04:54 [14,896ms] [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource '/home/syh/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/exts/omni.kit.helper.file_utils/data/thumbnails/usd_stage_256.png:2024-01-25@17:23:58'
2024-05-25 08:04:54 [14,896ms] [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource '/home/syh/.local/share/ov/pkg/isaac_sim-2023.1.1/kit/exts/omni.kit.window.filepicker/data/thumbnails/folder_256.png:2024-01-25@17:23:25'
2024-05-25 08:04:54 [14,901ms] [Warning] [omni.usd] Unexpected reference count of 2 for UsdStage 'anon:0x755cd0011410:World0.usd' while being closed in UsdContext (this may indicate it is still resident in memory).
2024-05-25 08:04:54 [15,041ms] [Warning] [omni.timeline.plugin] Deprecated: direct use of ITimeline callbacks is deprecated. Use ITimeline::getTimeline (Python: omni.timeline.get_timeline_interface) instead.
2024-05-25 08:04:54 [15,076ms] [Warning] [omni.physicsschema.plugin] ScaleOrientation is not supported for rigid bodies, prim path: /World/Objects/real_object0. You may ignore this if the scale is close to uniform.
The above warning appears and stops without pressing any buttons on the isaac sim. I’m sure it worked until yesterday, and other usd files open and work well. Which part should I fix to make it work?
