When I ran the deepstream example, I had to run the engine transformation on each execution
**• Hardware Platform (Jetson / GPU)jetson agx orin
**• DeepStream Version 6.4
**• JetPack Version (valid for Jetson only) 6.0
**• TensorRT Version 8.6.2
**• Issue Type( questions, new requirements, bugs) questions
When I run the deepstream example, I have to run the engine transformation on every execution. Is there any way to change this without the configuration of every transformation
You can try to modify the configuration file.
Take deepstream-test1 as an example. In the dstest1_pgie_config.txt, batch-size needs to be consistent with model-engine-file.
batch-size=30
model-engine-file=../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
Like this, the conversion will only happen when the sample first run.
