When I shut down, print the following report
Are you using devkit?
Which JetPack SW?
Is there any abnormal behavior on your device?
The “devkit” software is not used,
JetPack 4.6.3
No exception was found during use, and this exception only occurred when the machine was shut down
麻煩所有log都用文字擋分享… 這樣截圖其實也看不出東西
The “log” generated during shutdown is still there after startup? Where can I find it
請照這個方法抓uart log
