the follow is error info:
What could possibly cause this problem???how can i fix it???
Based on the provided context, it appears that you are experiencing an issue with your Jetson Orin Nano device, and you’ve shared an error message with an image (1039727, 110 KB). Unfortunately, I couldn’t view the image, but I’ll provide a general troubleshooting guide to help you identify and potentially fix the problem.
Common Issues on Jetson Orin Nano:
Troubleshooting Steps:
dmesg, syslog, or journalctl) for any error messages that might indicate the cause of the problem.Specific to Your Error Message:
Without the actual error message or image, it’s challenging to provide a precise solution. However, I recommend checking the system logs and container runtime logs for any error messages related to the image (1039727, 110 KB). You can also try searching for similar error messages on the NVIDIA Jetson forums or other online resources.
If you’re still unable to resolve the issue, please provide more details about the error message, your setup, and any relevant configuration files, and I’ll do my best to assist you further.
How do you flash your device using script?
Is your host a native ubuntu or a virtual machine?
Do you follow the quick start guide to flash your device?
my script as follow:
#!/bin/bash
image=$1
machine=$2
scriptdir=“$( cd “$( dirname “${BASH_SOURCE[0]}” )” >/dev/null && pwd )”
deployfile=${image}-${machine}.tegraflash.tar.gz
tmpdir=mktemp
rm -rf $tmpdir
mkdir -p $tmpdir
echo “Using temp directory $tmpdir”
pushd $tmpdir
cp $scriptdir/build/tmp/deploy/images/${machine}/$deployfile .
tar -xvf $deployfile
set -e
sudo /home/tvt/yocto-tegra/build/tmp/work/jetson_orin_nano_devkit_nvme-poky-linux/core-image-sato-dev/1.0-r0/tegraflash/doflash.sh
popd
echo “Removing temp directory $tmpdir”
rm -rf $tmpdir
and i excute the command: sudo ./deploy.sh core-image-sato-dev jetson-orin-nano-devkit-nvme
We notice that you could not read EEPROM board information.
Do you put the device in recovery mode?
Please try to use lsusb to check your status.
the follow is lsusb result:
tvt@tvt-virtual-machine:~/nvidia/nvidia_sdk/JetPack_6.1_Linux_JETSON_ORIN_NANO_8GB/Linux_for_Tegra/source$ lsusb
Bus 002 Device 011: ID 0955:7020 NVIDIA Corp. L4T (Linux for Tegra) running on Tegra
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 001 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Please refer to the official doc to check whether in recovery mode.
it is in recovery mode,because I shorted pins 9 and 10 on the J14 header of the development board
Could you take a picture for us to review?
What kind of pictures would you like to see? Are you referring to photos of the development board?
Please try to use other jumper to short the REC and GND pins.
If you could access the system, you could run sudo reboot --force forced-recovery.
