The following is the uart log when the device restarts :
[ 528.674435] pcieport 0001:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0000(Transmitter ID)
[ 528.674976] pcieport 0001:00:00.0: device [10de:1ad2] error status/mask=00001000/0000e000
[ 528.675310] pcieport 0001:00:00.0: [12] Replay Timer Timeout
[ 1132.298899] pcieport 0001:00:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0000(Transmitter ID)
[ 1132.299362] pcieport 0001:00:00.0: device [10de:1ad2] error status/mask=00001000/0000e000
[ 1132.299686] pcieport 0001:00:00.0: [12] Replay Timer Timeout
[ 1451.355091] INFO: task sync:14856 blocked for more than 120 seconds.
[ 1451.355385] Tainted: G O 4.9.201-tegra #1
[ 1451.355610] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
[ 1451.356125] Kernel panic - not syncing: hung_task: blocked tasks
[ 1451.356364] CPU: 2 PID: 706 Comm: khungtaskd Tainted: G O 4.9.201-tegra #1
[ 1451.356669] Hardware name: Jetson-AGX (DT)
[ 1451.356825] Call trace:
[ 1451.356938] [] dump_backtrace+0x0/0x198
[ 1451.357149] [] show_stack+0x24/0x30
[ 1451.357355] [] dump_stack+0xa0/0xc8
[ 1451.357563] [] panic+0x12c/0x2a8
[ 1451.357758] [] watchdog+0x320/0x3d0
[ 1451.357958] [] kthread+0xec/0xf0
[ 1451.358546] [] ret_from_fork+0x10/0x30
[ 1451.359433] SMP: stopping secondary CPUs
[ 1451.360084] Kernel Offset: disabled
[ 1451.360631] Memory Limit: none
[ 1451.361146] trusty-log panic notifier - trusty version Built: 14:49:44 Jan 15 2021 [ 1451.377033] Rebooting in 5 seconds…
ERROR: app/ivc-sync-in2-channel.c:84 [ivc_sync_in2_write_msg] “tegra_ivc_tx_get_contiguous_write_space() failed”
Shutdown state requested 1
Rebooting system …
