[TensorRT] ERROR: (Unnamed Layer* 605) [Deconvolution]: kernel weights has count 5242880 but 32768 was expected
here is my trt code:
import numpy as np
import pycuda.driver as cuda
# This import causes pycuda to automatically manage CUDA context creation and cleanup.
import pycuda.autoinit
import tensorrt as trt
import sys, os
sys.path.insert(1, os.path.join(sys.path[0], ".."))
import common
import random
from PIL import Image
import matplotlib.pyplot as plt
# You can set the logger severity higher to suppress messages (or lower to display more messages).
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
class ModelData(object):
MODEL_FILE = "exp14-Unet-efficientnetb0-2out-c-[2].uff"
INPUT_NAME = "input_1_1"
INPUT_SHAPE = (3, 512, 512)
OUTPUT_NAME_1 = 'c_2_1/Softmax'
OUTPUT_NAME_2 = "seg_1/Sigmoid"
def GiB(val):
return val * 1 << 30
def build_engine(model_file):
# For more information on TRT basics, refer to the introductory samples.
with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.UffParser() as parser:
builder.max_workspace_size = GiB(1)
# Parse the Uff Network
parser.register_input(ModelData.INPUT_NAME, ModelData.INPUT_SHAPE)
parser.register_output(ModelData.OUTPUT_NAME_1)
parser.register_output(ModelData.OUTPUT_NAME_2)
parser.parse(model_file, network)
# Build and return an engine.
return builder.build_cuda_engine(network)
# Loads a test case into the provided pagelocked_buffer.
def load_normalized_test_case(data_path, pagelocked_buffer, case_num=random.randint(0, 9)):
# test_case_path = os.path.join(data_path, str(case_num) + ".pgm")
# Flatten the image into a 1D array, normalize, and copy to pagelocked memory.
img = Image.open(data_path)
img = img.resize((512, 512))
img = np.array(img)
img = np.moveaxis(img, -1, 0)
img = img.ravel()
np.copyto(pagelocked_buffer, img / 255.0)
return case_num
def main():
# data_path, _ = common.find_sample_data(description="Runs an MNIST network using a UFF model file", subfolder="mnist")
data_path = 'data/3.png'
# model_path is current "models/"
model_path = os.environ.get("MODEL_PATH") or os.path.join(os.path.dirname(__file__), "models")
model_file = os.path.join(model_path, ModelData.MODEL_FILE)
with build_engine(model_file) as engine:
# Build an engine, allocate buffers and create a stream.
# For more information on buffer allocation, refer to the introductory samples.
inputs, outputs, bindings, stream = common.allocate_buffers(engine)
with engine.create_execution_context() as context:
case_num = load_normalized_test_case(data_path, pagelocked_buffer=inputs[0].host)
# For more information on performing inference, refer to the introductory samples.
# The common.do_inference function will return a list of outputs - we only have one in this case.
output = common.do_inference(context, bindings=bindings, inputs=inputs, outputs=outputs, stream=stream)
# out_img = output[1].reshape((512, 512))
# print('trt output is:', out_img[0:5, 0:5]) # output
# print('trt output is:', output[2])
print('Finish!')
if __name__ == '__main__':
main()
