When I use yolov7 with nvpreprocess the gpu run 100%
**• Hardware Platform (Jetson / GPU) Jetson
**• DeepStream Version 6.2
**• JetPack Version (valid for Jetson only) 5.1.1
**• TensorRT Version 8.5.2.2
**• Issue Type( questions, new requirements, bugs)bugs
Can you provide details about how to reproduce it?
Which Jetson module are you using? AGX Orin, Orin-NX or Orin Nano?
I ues jetson orin nx
here is my config:
[property]
enable=1
# list of component gie-id for which tensor is prepared
target-unique-ids=1
# 0=NCHW, 1=NHWC, 2=CUSTOM
network-input-order=0
# 0=process on objects 1=process on frames
process-on-frame=1
#uniquely identify the metadata generated by this element
unique-id=5
# gpu-id to be used
gpu-id=0
# if enabled maintain the aspect ratio while scaling
maintain-aspect-ratio=1
# if enabled pad symmetrically with maintain-aspect-ratio enabled
symmetric-padding=1
# processig width/height at which image scaled
processing-width=640
processing-height=640
# max buffer in scaling buffer pool
scaling-buf-pool-size=6
# max buffer in tensor buffer pool
tensor-buf-pool-size=6
# tensor shape based on network-input-order
network-input-shape= 4;3;640;640
# 0=RGB, 1=BGR, 2=GRAY
network-color-format=1
# 0=FP32, 1=UINT8, 2=INT8, 3=UINT32, 4=INT32, 5=FP16
tensor-data-type=0
# tensor name same as input layer name
tensor-name=images
# 0=NVBUF_MEM_DEFAULT 1=NVBUF_MEM_CUDA_PINNED 2=NVBUF_MEM_CUDA_DEVICE 3=NVBUF_MEM_CUDA_UNIFIED
scaling-pool-memory-type=0
# 0=NvBufSurfTransformCompute_Default 1=NvBufSurfTransformCompute_GPU 2=NvBufSurfTransformCompute_VIC
scaling-pool-compute-hw=0
# Scaling Interpolation method
# 0=NvBufSurfTransformInter_Nearest 1=NvBufSurfTransformInter_Bilinear 2=NvBufSurfTransformInter_Algo1
# 3=NvBufSurfTransformInter_Algo2 4=NvBufSurfTransformInter_Algo3 5=NvBufSurfTransformInter_Algo4
# 6=NvBufSurfTransformInter_Default
scaling-filter=1
# custom library .so path having custom functionality
custom-lib-path=/opt/nvidia/deepstream/deepstream/lib/gst-plugins/libcustom2d_preprocess.so
# custom tensor preparation function name having predefined input/outputs
# check the default custom library nvdspreprocess_lib for more info
custom-tensor-preparation-function=CustomTensorPreparation
[user-configs]
Below parameters get used when using default custom library nvdspreprocess_lib
network scaling factor
pixel-normalization-factor=0.003921568
mean file path in ppm format
#mean-file=
array of offsets for each channel
#offsets=
[group-0]
src-ids=0
custom-input-transformation-function=CustomAsyncTransformation
process-on-roi=1
roi-params-src-0=150;480;400;300
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
#0=RGB, 1=BGR
model-color-format=1
model-engine-file=engines/yolov7-fire-smoke-640-b4-fp16.engine
labelfile-path=labels/tx_fire_smoke.txt
0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=2
gie-unique-id=1
network-type=0
interval=20
is-classifier=0
1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
cluster-mode=2
parse-bbox-func-name=NvDsInferParseCustomEfficientNMS
custom-lib-path=/opt/nvidia/deepstream/deepstream-6.2/sources/libs/nvdsinfer_customparser/libnvds_infercustomparser.so
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.15
Duplicate with this topic. Already processed.
