The warning “iso bandwidth %uKB is not available, client” shows when the below function is called
static bool pre_t19x_iso_plat_register(u32 dedi_bw, enum tegra_iso_client client)
if (unlikely(dedi_bw > isomgr.max_iso_bw - isomgr.dedi_bw)) {
pr_err("iso bandwidth %uKB is not available, client %s\n",
dedi_bw, cname[client]);
return false;
return true;
and pre_t19x_iso_plat_register
call by this function
int __init isomgr_init(void)
int i;
mutex_init(&isomgr.lock);
if (tegra_get_chip_id() == TEGRA194)
isomgr.ops = t19x_isomgr_init();
else
isomgr.ops = pre_t19x_isomgr_init
for (i = 0; ; i++) {
if (isoclient_info[i].name)
client_valid[isoclient_info[i].client] = true;
else
break;
#ifdef CONFIG_COMMON_CLK
isomgr.bwmgr_handle = tegra_bwmgr_register(TEGRA_BWMGR_CLIENT_ISOMGR);
if (IS_ERR_OR_NULL(isomgr.bwmgr_handle)) {
pr_err("couldn't get handle from bwmgr. disabling isomgr.\n");
#else
isomgr.emc_clk = clk_get_sys("iso", "emc");
if (IS_ERR_OR_NULL(isomgr.emc_clk)) {
pr_err("couldn't find iso emc clock. disabling isomgr.\n");
#endif
test_mode = 1;
return 0;
isomgr.ops->isomgr_plat_init();
for (i = 0; i < isoclients; i++) {
if (isoclient_info[i].name) {
enum tegra_iso_client c = isoclient_info[i].client;
OBJ_REF_SET(&isomgr_clients[c].kref.refcount, 0);
init_completion(&isomgr_clients[c].cmpl);
isomgr_clients[c].bwmgr_handle = tegra_bwmgr_register(
isoclient_info[i].bwmgr_id);
if (IS_ERR_OR_NULL(isomgr_clients[c].bwmgr_handle)) {
pr_err("couldn't get %s's bwmgr handle\n",
isoclient_info[i].name);
isomgr_clients[c].bwmgr_handle = NULL;
#else
isomgr_clients[c].emc_clk = clk_get_sys(
isoclient_info[i].dev_name,
isoclient_info[i].emc_clk_name);
if (IS_ERR_OR_NULL(isomgr_clients[c].emc_clk)) {
pr_err("couldn't find %s %s clock",
isomgr_clients[c].emc_clk = NULL;
#endif
return 0;
isomgr_create_sysfs();
return 0;
fs_initcall(isomgr_init);
#endif
whats is the CONFIG_COMMON_CLK ?
and what doesn’t have my custom carrier board so I got this warning?
