if need,what is version?
thanks
You don’t need to install any GPU driver.
The Jetson series GPU driver is integrated into the OS so you already have it after flashing.
For Caffe installation, here is a tutorial for your reference:
[url]https://devtalk.nvidia.com/default/topic/1050177/jetson-tx2/caffe-for-jetson-tx2-with-jetpack-4-2/post/5332481/#5332481[/url]
hellow!Thanks you so mach.
I success install cafee-ssd,but when I use
make runtest -j1
I get error,like this:
F0506 17:36:52.747298 8275 pooling_layer.cu:212] Check failed: error == cudaSuccess (48 vs. 0) no kernel image is available for execution on the device
*** Check failure stack trace: ***
Aborted (core dumped)
can you help me? Thanks
My Makefile.config is thiss:
CUDA_ARCH := -gencode arch=compute_30,code=sm_30 \
-gencode arch=compute_35,code=sm_35 \
-gencode arch=compute_50,code=sm_50 \
-gencode arch=compute_52,code=sm_52 \
-gencode arch=compute_53,code=sm_53 \
-gencode arch=compute_53,code=compute_53
Hello AastaLLL,
I installed it successfully!
Good to know this : )
what performance do you get from the caffe-ssd?
