misaligned address
illegal memory access was encountered
I got two error messages. But I don’t know when these errors occur…
Please, let me know!
Thank you guys
misaligned address
Thank you guys
1 - What kind of misalignment are you referring to? Shared memory bank conflict?
2 - Generally referencing to invalid array position, like smaller than 0 or larger than its (length - 1).
Without seeing any code, I can only suggest you to look for some assignment like:
my_array[idx] = some_value;
And print “idx” on the screen BEFORE the assignment. Then you will know if idx is out of bounds at some point.
thank you for your reply.
I use only global memory. So there is no shared memory bank conflict.
I will check the GPU threads’ index. Thank you so much this is really helpful.
