When using cuda-gdb for debugging in CLion, setting a breakpoint within a kernel function causes CLion to freeze
When using cuda-gdb for debugging in CLion, setting a breakpoint within a kernel function causes CLion to freeze. However, when using cuda-gdb directly from the command line for debugging, everything works as expected without any issues.
1,Environment
Ubuntu 22.04
gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04)
2,CLion:2023.3.5
**3,Cuda driver:**12.2
thinkpad@thinkpad-ThinkPad-P53:~$ nvidia-smi
Wed Jul 24 12:41:30 2024
| NVIDIA-SMI 535.183.01             Driver Version: 535.183.01   CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Quadro T1000                   Off | 00000000:01:00.0  On |                  N/A |
| N/A   45C    P0              13W /  50W |    792MiB /  4096MiB |     10%      Default |
|                                         |                      |                  N/A |
4,Cuda toolkit: 12.0
thinkpad@thinkpad-ThinkPad-P53:~$ nvcc -V
Copyright (c) 2005-2022 NVIDIA Corporation
Built on Mon_Oct_24_19:12:58_PDT_2022
Cuda compilation tools, release 12.0, V12.0.76
Build cuda_12.0.r12.0/compiler.31968024_0
thinkpad@thinkpad-ThinkPad-P53:~$ cuda-gdb -v
NVIDIA (R) CUDA Debugger
12.0 release
Portions Copyright (C) 2007-2022 NVIDIA Corporation
GNU gdb (GDB) 12.1
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
5,Program(main.cu):
#include <iostream>
#include <cuda_runtime.h>
__global__ void multiplyArrays(float *dev_a, float *dev_b, float *dev_c, int N) {
    int index = blockIdx.x * blockDim.x + threadIdx.x;
    if (index < N) {
        dev_c[index] = dev_a[index] + dev_b[index];
int main() {
    int N = 100;
    float *h_a = new float[N];
    float *h_b = new float[N];
    float *h_c = new float[N];
    for (int i = 0; i < N; i++) {
        h_a[i] = 1.0f * i / N;
        h_b[i] = 1.0f * i / N;
    float *d_a, *d_b, *d_c;
    cudaMalloc((void**)&d_a, N * sizeof(float));
    cudaMalloc((void**)&d_b, N * sizeof(float));
    cudaMalloc((void**)&d_c, N * sizeof(float));
    cudaMemcpy(d_a, h_a, N * sizeof(float), cudaMemcpyHostToDevice);
    cudaMemcpy(d_b, h_b, N * sizeof(float), cudaMemcpyHostToDevice);
    int threadsPerBlock = 1;
    int blocksPerGrid = (N + threadsPerBlock - 1) / threadsPerBlock;
    multiplyArrays<<<blocksPerGrid, threadsPerBlock>>>(d_a, d_b, d_c, N);
    cudaDeviceSynchronize();
    cudaError_t error = cudaGetLastError();
    if (error != cudaSuccess) {
        std::cerr << "CUDA kernel failed: " << cudaGetErrorString(error) << std::endl;
        return 1;
    cudaMemcpy(h_c, d_c, N * sizeof(float), cudaMemcpyDeviceToHost);
        std::cout << "h_c[" << i << "] = " << h_c[i] << std::endl;
    cudaFree(d_a);
    cudaFree(d_b);
    cudaFree(d_c);
    delete[] h_a;
    delete[] h_b;
    delete[] h_c;
    return 0;
6.When set no breakpoint£ just run in debug£ program run successful.
/opt/cuda/hello/cmake-build-debug/hello
h_c[0] = 0
h_c[1] = 0.02
h_c[2] = 0.04
h_c[3] = 0.06
h_c[4] = 0.08
7,When using cuda-gdb direct and set a breakpoint on line 6 output
thinkpad@thinkpad-ThinkPad-P53:/opt/cuda/hello/cmake-build-debug$ cuda-gdb hello
12.0 release
GNU gdb (GDB) 12.1
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from hello...
(cuda-gdb) b 6
Breakpoint 1 at 0xb1e1: file /opt/cuda/hello/main.cu, line 10.
(cuda-gdb) r
Starting program: /opt/cuda/hello/cmake-build-debug/hello
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7ffff4dff000 (LWP 3763)]
[Detaching after fork from child process 3764]
[New Thread 0x7fffe9fff000 (LWP 3774)]
[New Thread 0x7fffe97fe000 (LWP 3775)]
[New Thread 0x7fffe8ffd000 (LWP 3776)]
[Switching focus to CUDA kernel 0, grid 1, block (0,0,0), thread (0,0,0), device 0, sm 0, warp 0, lane 0]
Thread 1 "hello" hit Breakpoint 1, multiplyArrays<<<(100,1,1),(1,1,1)>>> (dev_a=0x7fffc7200000, dev_b=0x7fffc7200200, dev_c=0x7fffc7200400, N=100) at /opt/cuda/hello/main.cu:6
6           int index = blockIdx.x * blockDim.x + threadIdx.x;
(cuda-gdb)
8,When set breakpoint(line 6 too) Clion output these and hang forever
8.1:in consel windows:
8.2:in Debugger->GDB window:
12.0 release
GNU gdb (GDB) 12.1
[New Thread 0x7ffff4dff000 (LWP 5833)]
[Detaching after fork from child process 5834]
[New Thread 0x7fffe9fff000 (LWP 5844)]
[New Thread 0x7fffe97fe000 (LWP 5845)]
[New Thread 0x7fffe8ffd000 (LWP 5846)]
At this point, it’s impossible to terminate the debugging session; even closing CLion results in a notification that “the process ‘hello’ is still running”. Choosing to abort leads to CLion continuously displaying a message saying ‘waiting for process detach.’ The only way to close CLion seems to be by using the ‘kill’ command in the terminal.
It appears that cuda-gdb is running normally, but Cion is unable to properly interface with cuda-gdb.
Hi, @user70447
Sorry for the issue you met. We don’t have official support for this yet.
Please consider to use Nsight Visual Studio Code Edition | NVIDIA | NVIDIA Developer
And for CLion support, please reach out to JetBrains directly.
