When using extension, I got ImportError: DLL load failed while importing cv2: The specified module could not be found
I am using extension template to write a program but I got import error for cv2. I have installed the latest opencv and tested using ./python.bat to run opencv program in issac sim and it is working fine. The other import libraries are also working fine. I am wondering how I can fix the opencv dependency issue for the extension. Thank you so much!
The hotfix fixed the issue.
