During the use of Isaac sim4.20, I encountered an issue with opening the USD freeze, but I was able to open the same USD using versions 2023.1 or 2022. And I have seen many people encounter the same situation as me. How should it be resolved?
In version 4.2.0, I deleted many things in USD before he could open it.
When I used the 2023 version, it opened very smoothly.
Physics tasks will freeze when they appear
Due to the large number of scene items, I am unable to upload my USD. I am very sorry.
[Warning] [omni.hydratexture.plugin] â/Render/OmniverseKit/HydraTextures/omni_kit_widget_viewport_ViewportTexture_0â is not a Usd.RenderProduct and cannot be used, reseting to â/Render/OmniverseKit/HydraTextures/omni_kit_widget_viewport_ViewportTexture_0â
And then I tested it many times. If there are fewer objects (about ten rigid bodies, thatâs collision body uses ConvexDecomposition, but no baked data), it may open normally. If there are more objects, it will basically get stuck. here are another test file with more objects, hope it helps.
Can the âUSD Composer 2023.2.5â or âIsaac Sim 2023.xâ application open this file? I tried using USD Composer, but it seemed stuck at 72%. Maybe I didnât wait long enough.
@goodlaijiaxin@VickNV
Iâm very sorry for my late reply.
I have made some attempts, and regarding âTestRoom_2â, I was able to successfully open it using âIsaac Sim 2023. 1.1â. However, when I used âIsaac Sim 4.2â, it froze and I couldnât open it. I waited for a long time but still couldnât open it.
And I noticed that there was very little content in the scene, even so I couldnât open it smoothly.
I can replicate the issue on a Windows laptop using the USD file from Collected_TestRoom_2.zip. I will discuss this with our team and provide an update here.
Iâm very sorry to disturb you.
Due to the issue of freezing in version 4.2, I would like to continue using the 2023 version. Where can I download the previous old version?
Please create a new topic for this issue, or wait for the upcoming release version, which will provide direct download links for some archived versions.
