I’m using a Jetson Nano Developer Kit with an HDMI monitor and a DP monitor.
When I use nvoverlaysink, I can use “display-id=1” to play on the DP monitor, “display-id=0” to play on the HDMI monitor. So I can play two 4K 30fps videos on two monitors at the same time.
But for nveglglessink, it always plays on the HDMI monitor. Is there any way to play on the DP monitor?
This “display” property looks close, but I haven’t figured out what value should be passed to it.
$ gst-inspect-1.0 nveglglessink
display : If set, the sink will use the passed X Display for rendering
flags: readable, writable
Pointer.
