My device is: Jetson AGX Orin Developer Kit
The version of jetpack is:
Package: nvidia-jetpack
Version: 5.1.2-b104
I tested jetson_multimedia_api/samples/05_jpeg_encode and added time printing in jpeg_encode_main.cpp. I found that when the DP monitor is connected, the time of end_time - start_time is about 11ms, but when the DP monitor is not connected, this time increases to more than 30ms. Can you explain this phenomenon?
Sorry, we need to develop based on the current Jetpack and cannot upgrade.
I have a few questions:
1, Can it be considered that NvJPEGEncoder does not use the GPU? Is it a bug that NvJPEGEncoder becomes slow when not connecting a DP monitor?
2, My image size is 1600*1300. Is the time of 11ms in line with expectations? The running frequency of NvJPG is 729MHz. Can it be improved? If it cannot be increased,How to improve NvJPG encoding performance?
If you would like to develop the use-case without display, would suggest run in headless mode. You may refer to developer guide to generate headless rootfs:
Can you further explain the impact of connecting a monitor and not connecting a monitor on the computing resources (CPU, GPU, etc.) in the system?
From the phenomenon, it seems that connecting a monitor helps improve the performance of NvJPEGEncoder::encodeFromFd(). This is a very interesting phenomenon. I would like to know the reason.
This is not a valid setup. We would expect display output device is present when it’s enabled in device tree. Certain use-cases may not work properly in the setup.
