when write message length is more than 1024B(mtu), it failed in softroce mode, pls help check why.
using the standard tool ib_write_lat to test: when ib_write_lat -s 1024 -n 5 when ib_write_lat -s 1025 -n 5, it fail.
my softroce version in in “Red Hat Enterprise Linux Server release 7.4 (Maipo)”
Is it a bug in softroce? Thanks!
Hi Tianyu,
Have you properly configured Soft-Roce whether upstream or Mellanox OFED Driver.
See reference links below:
HowTo Configure Soft-RoCE https://community.mellanox.com/s/article/howto-configure-soft-roce
How to configure Soft-RoCE with Mellanox OFED 4.x
Also, you original statement is confusing or contradicting itself:
when my write opcode with length=1024, it is ok. but when length=1025 in the same code, it will fail.
when the same code with length=1024 or 1025 run using mellanox CX4 card, it is ok >>> Apparently working.
Sophie.
Dear Tianyu
I have the same problem, any RDMA WR that is bigger than 1 MTU (1024B) fails on SoftROCE between two virtual machines in Virtualbox. (CentOS 7.4.1708, rdma-core-22.1-3.el7.x86_64 )
All examples i have tried (and my own code) fail at the same point so it looks like this is a problem with the driver somehow…
Did you get an answer ?
Phil.
