when x86_linux cross complie to arm_linux,it occur a error
When I build a docker for creat a cross complie env.docker occur a error like:
Step 6/15 : COPY docker/jetpack_files /pdk_files
COPY failed: stat /mnt/data_c/docker/tmp/docker-builder505941549/docker/jetpack_files: no such file or directory
I use the command:
docker build -f docker/ubuntu-18.04-cross-aarch64.Dockerfile --build-arg CUDA_VERSION=10.0 --tag=tensorrt .
My docker come from https://github.com/NVIDIA/TensorRT/blob/master/docker/ubuntu-18.04-cross-aarch64.Dockerfile
Its content is:
FROM nvidia/cuda:10.0-devel-ubuntu18.04
LABEL maintainer=“NVIDIA CORPORATION”
Install requried libraries
RUN apt-get update && apt-get install -y --no-install-recommends
libcurl4-openssl-dev
wget
zlib1g-dev
git
pkg-config
python3
python3-pip
RUN cd /usr/local/bin &&
ln -s /usr/bin/python3 python &&
ln -s /usr/bin/pip3 pip
Install Cmake
RUN cd /tmp &&
wget https://github.com/Kitware/CMake/releases/download/v3.14.4/cmake-3.14.4-Linux-x86_64.sh &&
chmod +x cmake-3.14.4-Linux-x86_64.sh &&
./cmake-3.14.4-Linux-x86_64.sh --prefix=/usr/local --exclude-subdir --skip-license &&
rm ./cmake-3.14.4-Linux-x86_64.sh
COPY scripts/stubify.sh /pdk_files
Install CUDA cross compile toolchain
RUN dpkg -i /pdk_files/cuda-repo-cross-aarch64-10-0-local-10.0.326_1.0-1_all.deb /pdk_files/cuda-repo-ubuntu1804-10-0-local-10.0.326-410.108_1.0-1_amd64.deb
&& apt-get update
&& apt-get install -y cuda-cross-aarch64
&& rm -rf /var/lib/apt/lists/*
Unpack cudnn
RUN dpkg -x /pdk_files/libcudnn7_7.5.0.56-1+cuda10.0_arm64.deb /pdk_files/cudnn
&& dpkg -x /pdk_files/libcudnn7-dev_7.5.0.56-1+cuda10.0_arm64.deb /pdk_files/cudnn
&& cd /pdk_files/cudnn/usr/include/aarch64-linux-gnu
&& cd /pdk_files/cudnn/usr/lib/aarch64-linux-gnu
&& ln -s libcudnn.so.7 libcudnn.so
&& ln -s usr/include/aarch64-linux-gnu include
&& ln -s usr/lib/aarch64-linux-gnu lib \
&& ln -s /pdk_files/cudnn/usr/include/aarch64-linux-gnu/cudnn_v7.h /usr/include/cudnn.h
Unpack libnvinfer
RUN dpkg -x /pdk_files/libnvinfer6_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvinfer-dev_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvparsers6_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvparsers-dev_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvinfer-plugin6_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvinfer-plugin-dev_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvonnxparsers6_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
&& dpkg -x /pdk_files/libnvonnxparsers-dev_6.0.1-1+cuda10.0_arm64.deb /pdk_files/tensorrt
create stub libraries
RUN cd /pdk_files/tensorrt
&& cd lib
&& mkdir stubs
&& for x in nvinfer nvparsers nvinfer_plugin nvonnxparser;
do
CC=aarch64-linux-gnu-gcc /pdk_files/stubify.sh lib${x}.so stubs/lib${x}.so
; done
Set environment and working directory
ENV TRT_RELEASE /pdk_files/tensorrt
ENV TRT_SOURCE /workspace/TensorRT
WORKDIR /workspace
RUN ["/bin/bash"]
Please noticed that this Dockefile should be executed on an x86 environment.
Are you trying to build it on the TX2?
Hi AastaLLL
I run it on my X86 PC and my target platform is TX2(ARMV8)
The file scripts/stubify.sh it is not in the current github repository (https://github.com/NVIDIA/TensorRT.git)
This is a known issue.
We are checking the status of stubify.sh with our internal team.
Will update more information here once we got a feedback.
Please find the attachment for the script.
Remember to fix the naming back to stubify.sh (limitation to attach a file here)
stubify.sh.txt (907 Bytes)
