Where are I need set the parameter if I use GMSL Camera at TX2 ?
hello sensor_test,
what’s the parameter you would like to set?
I need enable the GMSL camera,How can I enable it?
and I need disp the video,How can I disp the GMSL camera?
hello sensor_test,
please, besides create several discussion threads everywhere.
share more details and stick same issue at single discussion thread would help you more.
you might contact with Jetson Preferred Partner for workable GMSL cameras.
you could also access these camera sensors as normal bayer sensor, please check Camera Software Development Solution chapter for the commands. thanks
