Hello there,
I am currently working on a project which uses a Jetson nano and an Arduino Uno and I am working on a serial connection between them.
FYI I am using this set of documentation: Sign In
(Sorry if the link does not work in advance)
So the question I have is where are the modules from Jupyter Labs in python files stored? As seen by the screenshots below, I tried to import pyserial and I was able to get the Notebook to store locally on the Jetson but I cant figure out how to get pyserial to also install locally in the “data” directory which is the directory which is loaded when I load the docker file using this command: ./docker_dli_run.sh
Here is a screenshot of the files which I managed to get locally loaded to the Jetson:
And here is a screenshot of the code which gives an error that says it could not find the pyserial module:
What I can do is install pyserial every time I want to run this although it would become more difficult as I add more things to my project. If anyone can give advice as to what I should do/can tell me where the imports are stored in Jupyter labs, that would be great! Also please tell me if I have to include any more information as to what my issue is.
See your docker_dli_run.sh. Maybe it has --rm option.
See also the docker run documentation.
The --rm option deletes the container when it is exited.
This provides the same environment upon restart as the first time. This means that if you accidentally delete a code or something, a restart will restore the original environment.
However, as in your case, it also undoes the necessary updates.
It is recommended that you are at least familiar with the following docker commands.
Hello naisy,
I will look through the documentation and another quick question I have is that as seen in the screenshot below (I manually installed pyserial for this demo), it shows with an error that it could not open /dev/ttyACM0’s port and I was wondering is it something to do with what is inside the docker.sh script? and how would I change it? Would I just add /dev/ttyACM0/seperated by a comma after the /dev/video0line?
The error:
SerialException: [Errno 2] could not open port /dev/ttyACM0: [Errno 2] No such file or directory: '/dev/ttyACM0'
Hello again, Sorry for being such as mess but I got it to work, looks like I forgot to save the edits to the docker file and instead I just quit it without saving. All works now! thanks for the help!
Did you run docker commit? commit updates the docker image.
A container is created from the image. And you are working in the container. --rm option deletes container if you exit docker container.
If the container remains, you can simply use the same container next time.
You don’t need to save the container to image, if you remove --rm option from docker run command.
How would I run the docker commit command because yesterday i tried out docker commit IMAGES and it did not save the module and i had to install pyserial again. What would I put after docker commit?
