I am using the detectnet_v2 notebook (tao 5…0.0) as is but with some custom dataset.
Once I am done with the training, I want to evaluate using:
!tao model detectnet_v2 evaluate -e $SPECS_DIR/detectnet_v2_train_resnet18_kitti-1Class.txt\
-m $USER_EXPERIMENT_DIR/experiment_dir_unpruned/weights/resnet50_detector.hdf5
I got an error saying that the model could not be found.
I checked whether the models are here:
print('Model for each epoch:')
print('---------------------')
!ls -lh $LOCAL_EXPERIMENT_DIR/experiment_dir_unpruned/weights
gives:
total: 0
Any suggestion to debug this issue?
What if I want to evaluate a specific epoch? Is there a standard format where models are named? for example model_name.epoch_<epoch_num>.hdf5?
Training spec:
random_seed: 42
dataset_config {
data_sources {
tfrecords_path: "/workspace/tao-experiments/data/tfrecords/kitti_trainval/*"
image_directory_path: "/workspace/tao-experiments/data/training"
image_extension: "png"
target_class_mapping {
key: "rumex"
value: "rumex"
} validation_fold: 0
augmentation_config {
preprocessing {
output_image_width: 2048
output_image_height: 1376
min_bbox_width: 1.0
min_bbox_height: 1.0
output_image_channel: 3
enable_auto_resize: true
spatial_augmentation {
hflip_probability: 0.5
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
hue_rotation_max: 25.0
saturation_shift_max: 0.20000000298
contrast_scale_max: 0.10000000149
contrast_center: 0.5
postprocessing_config {
target_class_config {
key: "rumex"
value {
clustering_config {
clustering_algorithm: DBSCAN
dbscan_confidence_threshold: 0.9
coverage_threshold: 0.00499999988824
dbscan_eps: 0.20000000298
dbscan_min_samples: 1
minimum_bounding_box_height: 20
model_config {
pretrained_model_file: "/workspace/tao-experiments/detectnet_v2/pretrained_resnet50/pretrained_detectnet_v2_vresnet50/resnet50.hdf5"
num_layers: 50
freeze_blocks: 0
freeze_blocks: 1
use_batch_norm: true
objective_set {
bbox {
scale: 35.0
offset: 0.5
cov {
arch: "resnet"
evaluation_config {
validation_period_during_training: 10
first_validation_epoch: 30
minimum_detection_ground_truth_overlap {
key: "rumex"
value: 0.25
evaluation_box_config {
key: "rumex"
value {
minimum_height: 10
maximum_height: 1000
minimum_width: 10
maximum_width: 1000
average_precision_mode: INTEGRATE
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.0500000007451
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 10.0
enable_autoweighting: false
max_objective_weight: 0.999899983406
min_objective_weight: 9.99999974738e-05
training_config {
batch_size_per_gpu: 2
num_epochs: 2000
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-07
max_learning_rate: 5e-05
soft_start: 0.10000000149
annealing: 0.699999988079
regularizer {
type: L1
weight: 3.00000002618e-09
optimizer {
adam {
epsilon: 9.99999993923e-09
beta1: 0.899999976158
beta2: 0.999000012875
cost_scaling {
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
visualizer{
enabled: true
num_images: 3
scalar_logging_frequency: 10
infrequent_logging_frequency: 5
key: "rumex"
value: {
coverage_threshold: 0.005
clearml_config{
project: "TAO DetectNet 1 Class"
task: "detectnet_v2_resnet50_clearml"
tags: "detectnet_v2"
tags: "training"
tags: "resnet50"
tags: "unpruned"
checkpoint_interval: 10
bbox_rasterizer_config {
key: "rumex"
value {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.8 #0.40000000596
cov_radius_y: 0.8 #0.40000000596
bbox_min_radius: 1.0
deadzone_radius: 0.400000154972
