We are using an eDP panel and would like to control its power through the DP driver. When system suspend/resume, the panel power can be output high or low.
We added some printk in Linux_for_Tegra/source/kernel/kernel-jammy-src/drivers/gpu/drm, but the logs are not appearing in dmesg
I noticed another display driver called nvdisplay. If I want to control the panel power, should I add the control logic to nvdisplay instead?
"It seems there was a misunderstanding in my previous explanation. We are successfully outputting a signal to an eDP panel via the DP port. So, my question should be about the DP driver’s suspend/resume functionality.
I’ve tried adding log to Linux_for_Tegra/source/kernel/kernel-jammy-src/drivers/gpu/drm, but they aren’t showing up as I anticipated. So the question is which file or folder would be the appropriate place to add GPIO control for powering the panel on and off during DP suspend/resume?"
