Where can I find gdsio.cu file in CUDA toolkit or any other src location?
I am trying to compile gdsio as per my GPU Simulator environment, and I am not able to find gdsio.cu file in CUDA toolkit which I can compile as per my requirement.
Kindly share some details about it.
are you referring to this tool?
I don’t believe the source code for it is provided. You could confirm that by installing GDS and then doing a search of the files installed.
I installed GDS but can’t find gdsio.cu in it.
