I did 2 mistakes
The matrixLayout
was not properly set, I wrote a function to write it before each multiplication based on the op
applied to the matrix.
Additionally I put the matrix memory row major instead of column major.
Now the code is working well for square and non square product and row major memory.
cublaslt_mat_mul.cu
#include <iostream>
#include <iomanip>
#include <limits>
#include <vector>
#include <cxxabi.h>
#include <cuda_runtime.h>
#include <cuda_runtime_api.h>
#include <cublasLt.h>
// ErrorsCheck.cuh //
static const char* cublasGetErrorEnum(cublasStatus_t error)
switch (error)
case CUBLAS_STATUS_SUCCESS:
return "CUBLAS_STATUS_SUCCESS";
case CUBLAS_STATUS_NOT_INITIALIZED:
return "CUBLAS_STATUS_NOT_INITIALIZED";
case CUBLAS_STATUS_ALLOC_FAILED:
return "CUBLAS_STATUS_ALLOC_FAILED";
case CUBLAS_STATUS_INVALID_VALUE:
return "CUBLAS_STATUS_INVALID_VALUE";
case CUBLAS_STATUS_ARCH_MISMATCH:
return "CUBLAS_STATUS_ARCH_MISMATCH";
case CUBLAS_STATUS_MAPPING_ERROR:
return "CUBLAS_STATUS_MAPPING_ERROR";
case CUBLAS_STATUS_EXECUTION_FAILED:
return "CUBLAS_STATUS_EXECUTION_FAILED";
case CUBLAS_STATUS_INTERNAL_ERROR:
return "CUBLAS_STATUS_INTERNAL_ERROR";
case CUBLAS_STATUS_NOT_SUPPORTED:
return "CUBLAS_STATUS_NOT_SUPPORTED";
case CUBLAS_STATUS_LICENSE_ERROR:
return "CUBLAS_STATUS_LICENSE_ERROR";
default:
return "<unknown>";
inline void cublasLtCheck(cublasStatus_t status, int iLine, const char *szFile) {
if (status != CUBLAS_STATUS_SUCCESS) {
std::cerr << "CublasLt error " << cublasGetErrorEnum(status) << " at line " << iLine << " in file "
<< szFile << std::endl;
inline void cudaCheck(cudaError_t status, int iLine, const char *szFile) {
if (status != cudaSuccess) {
std::cerr << "CublasLt error " << cudaGetErrorString(status) << " at line " << iLine << " in file "
#define cublasLtCk(call) cublasLtCheck(call, __LINE__, __FILE__)
#define cudaCk(call) cudaCheck(call, __LINE__, __FILE__)
// CudaMatrix.cuh //
#define MB 1048576 // 2^19 byte
typedef unsigned int uint;
template <typename precision>
struct CudaMatrix {
// Matrix multiplication GPU workspace that can be used to improve matrix multiplication computation time
const static void *matMulWorkspace;
const static size_t matMulWorkspaceSize;
CudaMatrix() : width(0), height(0), data(nullptr), cublasHandle(nullptr), cublasLtHandle(nullptr), matrixLayout(nullptr) { };
CudaMatrix(uint width, uint height, cublasHandle_t cublasHandle = nullptr, cublasLtHandle_t cublasLtHandle = nullptr,
cublasLtMatrixLayout_t matrixLayout = nullptr) : width(width), height(height), cublasHandle(cublasHandle),
cublasLtHandle(cublasLtHandle), matrixLayout(matrixLayout)
cudaCk(cudaMalloc(&data, bytesSize()));
if (typeid(precision).hash_code() == typeid(uint).hash_code()) {
cublasLtDataType = CUDA_R_8U;
} else if (typeid(precision).hash_code() == typeid(int).hash_code()) {
cublasLtDataType = CUDA_R_8I;
} else if (typeid(precision).hash_code() == typeid(float).hash_code()) {
cublasLtDataType = CUDA_R_32F;
} else if (typeid(precision).hash_code() == typeid(double).hash_code()) {
cublasLtDataType = CUDA_R_64F;
} else {
throw std::runtime_error("The datatype " + std::string(typeid(precision).name()) + " is not handled in CudaMatrix");
if (matMulWorkspace == nullptr) {
cudaCk(cudaMalloc(&matMulWorkspace, matMulWorkspaceSize));
__device__ __host__ uint size() const { return width * height; }
static void product(CudaMatrix &A, CudaMatrix &B, CudaMatrix &C, cublasOperation_t opA, cublasOperation_t opB, cublasLtHandle_t lightHandle);
void freeResources() { cudaCk(cudaFree(data)); cublasLtCk(cublasLtMatrixLayoutDestroy(matrixLayout)); }
void setMatrixLayout(cublasOperation_t op, cublasLtOrder_t matrixOrder = CUBLASLT_ORDER_ROW);
uint bytesSize() const { return size() * sizeof(precision); }
void setValuesFromVector(const std::vector<precision> &vector);
void setValuesFromVector(const std::vector<std::vector<precision>> &vectors);
void display(const std::string &name = "", uint x = 0, uint y = 0, uint roiWidth = 0, uint roiHeight = 0) const;
void product(CudaMatrix &A) { product(*this, A, *this, CUBLAS_OP_N, CUBLAS_OP_N, cublasLtHandle); }
precision *data;
uint width,
height;
cublasHandle_t cublasHandle;
cublasLtHandle_t cublasLtHandle;
cublasLtMatrixLayout_t matrixLayout;
cudaDataType_t cublasLtDataType;
template <typename precision> const size_t CudaMatrix<precision>::matMulWorkspaceSize = 500 * MB;
template <typename precision> const void* CudaMatrix<precision>::matMulWorkspace = nullptr;
// CudaMatrix.cu //
* Display the matrix
* @tparam precision - The matrix precision
* @param name - The matrix name
void CudaMatrix<precision>::display(const std::string &name, uint x, uint y, uint roiWidth, uint roiHeight) const
precision *hostValues;
roiWidth == 0 ? roiWidth = width : roiWidth = roiWidth;
roiHeight == 0 ? roiHeight = height : roiHeight = roiHeight;
cudaCk(cudaMallocHost(&hostValues, bytesSize()));
cudaCk(cudaMemcpy(hostValues, data, bytesSize(), cudaMemcpyDeviceToHost));
std::cout << std::setprecision(std::numeric_limits<precision>::digits10 + 1);
std::cout << "Matrix " << name << " " << width << " x " << height << " pixels of "
<< abi::__cxa_demangle(typeid(precision).name(), nullptr, nullptr, nullptr)
<< "\n\n";
for (int i = y; i < y + roiHeight; ++i) {
std::cout << "{ ";
for (int j = x; j < x + roiWidth - 1; ++j) {
std::cout << *(hostValues + i * width + j) << ", ";
std::cout << *(hostValues + (i + 1) * width - 1) << " }\n";
std::cout << std::endl;
cudaCk(cudaFreeHost(hostValues));
* Set the matrix values in device CUDA memory from a host standard 1D vector
* @param vector - The values to set the device CUDA memory from
void CudaMatrix<precision>::setValuesFromVector(const std::vector<precision> &vector)
cudaCk(cudaMemcpy(data, vector.data(), vector.size() * sizeof(precision), cudaMemcpyHostToDevice));
* Set the matrix values in device CUDA memory from a host standard 2D vector
* @param vectors - The values to set the device CUDA memory from
void CudaMatrix<precision>::setValuesFromVector(const std::vector<std::vector<precision>> &vectors)
std::vector<precision> buffer;
buffer.reserve(vectors.size() * vectors[0].size());
for (const auto &vector : vectors) {
buffer.insert(buffer.end(), vector.begin(), vector.end());
setValuesFromVector(buffer);
* Set the matrix layout before matrix multiplication with row major memory by default
* @param op - Operation to perform on matrix before multiplication (none, transpose or hermitian)
* @param matrixOrder - The matrix memory order (column or row DEFAULT row)
template<typename precision>
void CudaMatrix<precision>:: setMatrixLayout(cublasOperation_t op, cublasLtOrder_t matrixOrder)
const uint m = (op == CUBLAS_OP_N ? height : width),
n = (op == CUBLAS_OP_N ? width : height);
cublasLtCk(cublasLtMatrixLayoutCreate(&matrixLayout, cublasLtDataType, m, n, height));
cublasLtCk(cublasLtMatrixLayoutSetAttribute(matrixLayout, CUBLASLT_MATRIX_LAYOUT_ORDER, &matrixOrder, sizeof(matrixOrder)));
* Performs the matrix-matrix multiplication C = A x B
* @see https://docs.nvidia.com/cuda/cublas/index.html#cublasLtMatmul
* @param A - The left matrix A
* @param B - The right matrix B
* @param C - The result matrix C
* @param opA - Operation to perform on matrix A before multiplication (none, transpose or hermitian)
* @param opB - Operation to perform on matrix B before multiplication (none, transpose or hermitian)
* @param lightHandle - cublasLt handle
void CudaMatrix<precision>::product(CudaMatrix &A,
CudaMatrix &B,
CudaMatrix &C,
const precision zero = 0,
one = 1;
const int requestedAlgoCount = 1;
cudaStream_t stream = nullptr;
cublasLtMatmulHeuristicResult_t heuristicResult;
cublasLtMatmulPreference_t preference;
cublasLtMatmulDesc_t computeDesc;
int returnedAlgoCount;
// Set matrix pre-operation such as transpose if any
cublasLtCk(cublasLtMatmulDescCreate(&computeDesc, A.cublasLtDataType));
cublasLtCk(cublasLtMatmulDescSetAttribute(computeDesc, CUBLASLT_MATMUL_DESC_TRANSA, &opA, sizeof(opA)));
cublasLtCk(cublasLtMatmulDescSetAttribute(computeDesc, CUBLASLT_MATMUL_DESC_TRANSB, &opB, sizeof(opB)));
// Set matrices layout
A.setMatrixLayout(opA);
B.setMatrixLayout(opB);
C.setMatrixLayout(CUBLAS_OP_N);
// Get the best algorithm to use
cublasLtCk(cublasLtMatmulPreferenceCreate(&preference));
cublasLtCk(cublasLtMatmulPreferenceSetAttribute(preference, CUBLASLT_MATMUL_PREF_MAX_WORKSPACE_BYTES,
&CudaMatrix::matMulWorkspaceSize, sizeof(CudaMatrix::matMulWorkspaceSize)));
cublasLtCk(cublasLtMatmulAlgoGetHeuristic(lightHandle, computeDesc, A.matrixLayout, B.matrixLayout,
C.matrixLayout, C.matrixLayout, preference, requestedAlgoCount, &heuristicResult, &returnedAlgoCount));
// Do the multiplication
cublasLtCk(cublasLtMatmul(lightHandle, computeDesc, &one, A.data, A.matrixLayout, B.data, B.matrixLayout, &zero,
C.data, C.matrixLayout, C.data, C.matrixLayout, &heuristicResult.algo,
&CudaMatrix::matMulWorkspace, CudaMatrix::matMulWorkspaceSize, stream));
// clean up
cublasLtCk(cublasLtMatmulPreferenceDestroy(preference));
cublasLtCk(cublasLtMatmulDescDestroy(computeDesc));
// Forward template declarations
template struct CudaMatrix<double>;
template struct CudaMatrix<float>;
template struct CudaMatrix<int>;
template struct CudaMatrix<uint>;
// main.cu //
int main(int argc, char const *argv[])
cublasLtHandle_t cublasLtHandle = nullptr;
std::vector<float> r1Expect = { 6, 6, 6, 15, 15, 15, 24, 24, 24 };
std::vector<float> r2Expect = { 1, 2, 3, 4, 5, 6, 7, 8, 9 };
cublasLtCk(cublasLtCreate(&cublasLtHandle));
// Declare matrices
CudaMatrix<float> m1(3, 3);
CudaMatrix<float> m2(3, 3);
CudaMatrix<float> m3(3, 3);
CudaMatrix<float> m4(3, 2);
CudaMatrix<float> m5(2, 3);
CudaMatrix<float> deviceResult_2_2(2, 2);
CudaMatrix<float> deviceResult_3_3(3, 3);
// Set device memory values
m1.setValuesFromVector({ {1, 1, 1}, {1, 1, 1}, {1, 1, 1} });
m2.setValuesFromVector({ {1, 2, 3}, {4, 5, 6}, {7, 8, 9} });
m3.setValuesFromVector({ {1, 0, 0}, {0, 1, 0}, {0, 0, 1} });
m4.setValuesFromVector({ {1, 2, 3}, {4, 5, 6} });
m5.setValuesFromVector({ {1, 2}, { 3, 4 }, { 5 , 6 } });
// Test results (just showing it here)
CudaMatrix<float>::product(m1, m2, deviceResult_3_3, CUBLAS_OP_N, CUBLAS_OP_N, cublasLtHandle);
deviceResult_3_3.display("m1 X m2");
CudaMatrix<float>::product(m2, m3, deviceResult_3_3, CUBLAS_OP_N, CUBLAS_OP_N, cublasLtHandle);
deviceResult_3_3.display("m2 X m3");
CudaMatrix<float>::product(m4, m5, deviceResult_3_3, CUBLAS_OP_N, CUBLAS_OP_N, cublasLtHandle);
deviceResult_3_3.display("m4 X m5");
CudaMatrix<float>::product(m5, m4, deviceResult_2_2, CUBLAS_OP_N, CUBLAS_OP_N, cublasLtHandle);
deviceResult_2_2.display("m5 X m4");
// Clean up
cublasLtCk(cublasLtDestroy(cublasLtHandle));
m1.freeResources();
m2.freeResources();
m3.freeResources();
deviceResult_2_2.freeResources();
deviceResult_3_3.freeResources();
return 0;
