Where Can I get K1's I2C register map
Dear,
This issue is concerned with my previous postings about TPM 1.2 module at U-Boot.
TPM 1.2(slb9645tt) is connected GEN2 I2C.
I2C seems work well, but TPM does not. I can read registers of TPM through i2c command.
I cannot find an answer yet.
On Linux, interestingly, TPM works pretty well.
To compare I2C configuration between Linux kernel and U-Boot, I would like to look K1’s I2C register map.
Where can i get it?
mipsan
@mipsan
You can check the TRM chapter 31 I2C Controller.
Thanks ShaneCCC,
I found it and downloaded.
