where could I found a example code of spi driver on tx2 ?
now,there is a customer design base board,and on this board,a FPGA communicate with tx2 through spi1 bus.
I modified the spi4(Model is spi1,but the truth is spi4) of device tree,and successfully to make dts to dtb.
but I can’t found a example of spi driver in kernel_source_path/driver/spi/ path,or I need to read spi.c,spidev.c,spi-tegra114.c ? It seems the tx2 board have spi bus,but not use.
I just want to know how to use the spi function in a driver on tx2.for example,in a i2c driver,I use the function like this:
1.configure the i2c struct
2.fill the message struct
3.translate the message:i2c_transfer(…).
Hi XuXiang,
Please follow the wiki: https://elinux.org/Jetson/TX2_SPI
Or you could refer to similar topic: https://devtalk.nvidia.com/default/topic/1024806/jetson-tx2/how-to-enable-spi-spidev-on-28-1-on-target-/
Thanks for your reply.
May be my English is poor…
I have had successfully modified&compiled&flashed the dts,after login in the ubuntu(tx2 board) with ssh,use this command :“dir /dev/spi*” ,I can see spi3.0 spi3.1 .
I just want to get a example,to show me how to use spi function in a driver.
Check this to know how to …
 * imx204.c - imx204 sensor driver
 * Copyright (c) 2017-2018, NVIDIA CORPORATION.  All rights reserved.
 * This program is free software; you can redistribute it and/or modify it
 * under the terms and conditions of the GNU General Public License,
 * version 2, as published by the Free Software Foundation.
 * This program is distributed in the hope it will be useful, but WITHOUT
 * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
 * FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for
 * more details.
 * You should have received a copy of the GNU General Public License
 * along with this program.  If not, see <http://www.gnu.org/licenses/>.
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <linux/gpio.h>
#include <linux/module.h>
#include <linux/seq_file.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <linux/regmap.h>
#include <soc/tegra/chip-id.h>
#include <media/camera_common.h>
#include <media/imx204.h>
#include "imx204_mode_tbls.h"
#include "../platform/tegra/camera/camera_gpio.h"
#define IMX204_MAX_COARSE_DIFF		10
#define IMX204_GAIN_SHIFT		8
#define IMX204_MIN_GAIN		(1 << IMX204_GAIN_SHIFT)
#define IMX204_MAX_GAIN		(23 << IMX204_GAIN_SHIFT)
#define IMX204_MIN_FRAME_LENGTH	(0x0E51)
#define IMX204_MAX_FRAME_LENGTH	(0xffff)
#define IMX204_MIN_EXPOSURE_COARSE	(0x0001)
#define IMX204_MAX_EXPOSURE_COARSE	\
	(IMX204_MAX_FRAME_LENGTH-IMX204_MAX_COARSE_DIFF)
#define IMX204_DEFAULT_GAIN		IMX204_MIN_GAIN
#define IMX204_DEFAULT_FRAME_LENGTH	(0x0E51)
#define IMX204_DEFAULT_EXPOSURE_COARSE	\
	(IMX204_DEFAULT_FRAME_LENGTH-IMX204_MAX_COARSE_DIFF)
#define IMX204_DEFAULT_MODE	IMX204_MODE_5352x3950
#define IMX204_DEFAULT_WIDTH	5352
#define IMX204_DEFAULT_HEIGHT	3950
#define IMX204_DEFAULT_DATAFMT	MEDIA_BUS_FMT_SRGGB10_1X10
#define IMX204_DEFAULT_CLK_FREQ	72000000
struct imx204 {
	struct camera_common_power_rail	power;
	struct v4l2_ctrl_handler	ctrl_handler;
	int				num_ctrls;
	struct spi_device		*spi;
	struct device			*dev;
	struct v4l2_subdev		*subdev;
	struct media_pad		pad;
	s32				group_hold_prev;
	u32				prevSvr;
	bool				group_hold_en;
	struct regmap			*regmap;
	struct camera_common_data	*s_data;
	struct camera_common_pdata	*pdata;
	struct v4l2_ctrl		*ctrls[];
static const struct regmap_config sensor_regmap_config = {
	.reg_bits = 24,
	.val_bits = 8,
	.cache_type = REGCACHE_NONE,
static int imx204_g_volatile_ctrl(struct v4l2_ctrl *ctrl);
static int imx204_s_ctrl(struct v4l2_ctrl *ctrl);
static const struct v4l2_ctrl_ops imx204_ctrl_ops = {
	.g_volatile_ctrl = imx204_g_volatile_ctrl,
	.s_ctrl		= imx204_s_ctrl,
static struct v4l2_ctrl_config ctrl_config_list[] = {
/* Do not change the name field for the controls! */
		.ops = &imx204_ctrl_ops,
		.id = TEGRA_CAMERA_CID_GAIN,
		.name = "Gain",
		.type = V4L2_CTRL_TYPE_INTEGER,
		.flags = V4L2_CTRL_FLAG_SLIDER,
		.min = IMX204_MIN_GAIN,
		.max = IMX204_MAX_GAIN,
		.def = IMX204_DEFAULT_GAIN,
		.step = 1,
		.id = TEGRA_CAMERA_CID_FRAME_LENGTH,
		.name = "Frame Length",
		.min = IMX204_MIN_FRAME_LENGTH,
		.max = IMX204_MAX_FRAME_LENGTH,
		.def = IMX204_DEFAULT_FRAME_LENGTH,
		.step = 1,
		.id = TEGRA_CAMERA_CID_COARSE_TIME,
		.name = "Coarse Time",
		.min = IMX204_MIN_EXPOSURE_COARSE,
		.max = IMX204_MAX_EXPOSURE_COARSE,
		.def = IMX204_DEFAULT_EXPOSURE_COARSE,
		.step = 1,
		.id = TEGRA_CAMERA_CID_GROUP_HOLD,
		.name = "Group Hold",
		.type = V4L2_CTRL_TYPE_INTEGER_MENU,
		.min = 0,
		.max = ARRAY_SIZE(switch_ctrl_qmenu) - 1,
		.menu_skip_mask = 0,
		.def = 0,
		.qmenu_int = switch_ctrl_qmenu,
		.id = TEGRA_CAMERA_CID_HDR_EN,
		.name = "HDR enable",
		.min = 0,
		.def = 0,
static inline void imx204_get_svr_regs(imx204_reg *regs,
				u32 svr)
	regs->addr = (IMX204_CHIP_ID << 16) | IMX204_SVR_ADDR_LSB;
	regs->val = svr & 0xFF;
	(regs + 1)->addr = (IMX204_CHIP_ID << 16) | IMX204_SVR_ADDR_MSB;
	(regs + 1)->val = (svr >> 8) && 0xFF;
static inline void imx204_get_frame_length_regs(imx204_reg *regs,
				u32 frame_length)
	regs->addr = (IMX204_CHIP_ID << 16) | IMX204_FRAME_LENGTH_ADDR_LSB;
	regs->val = frame_length  & 0xFF;
		IMX204_FRAME_LENGTH_ADDR_MSB;
	(regs + 1)->val = (frame_length >> 8) & 0xFF;
static inline void imx204_get_coarse_time_regs(imx204_reg *regs,
				u32 coarse_time)
	regs->addr = (IMX204_CHIP_ID << 16) | IMX204_SHR_ADDR_LSB;
	regs->val = coarse_time & 0xFF;
	(regs + 1)->addr = (IMX204_CHIP_ID << 16) | IMX204_SHR_ADDR_MSB;
	(regs + 1)->val = (coarse_time >> 8) & 0xFF;
static inline void imx204_get_gain_reg(imx204_reg *regs,
				u16 gain)
	regs->addr = (IMX204_CHIP_ID << 16) | IMX204_PGC_ADDR_LSB;
	regs->val = gain & 0xFF;
	(regs + 1)->addr = (IMX204_CHIP_ID << 16) | IMX204_PGC_ADDR_MSB;
	(regs + 1)->val = (gain >> 8) & IMX204_PGC_MSB_MASK;
static int test_mode;
module_param(test_mode, int, 0644);
static inline int imx204_read_reg(struct camera_common_data *s_data,
				u16 addr, u8 *val)
	struct imx204 *priv = (struct imx204 *)s_data->priv;
	u32 addr32 = ((0x81<<16)|(addr));
	return regmap_read(priv->regmap, addr32, (unsigned int *) val);
static int imx204_write_reg(struct camera_common_data *s_data, u16 addr, u8 val)
	int err;
	u32 addr32 = ((IMX204_CHIP_ID<<16)|(addr));
	err = regmap_write(priv->regmap, addr32, val);
	if (err)
		dev_err(priv->dev, "%s:spi write failed, %x = %x\n",
			__func__, addr, val);
	return err;
static int imx204_write_reg32(struct camera_common_data *s_data,
				u32 addr, u8 val)
	int err = 0;
	err = regmap_write(priv->regmap, addr, val);
	if (err)
	return err;
static int imx204_write_table(struct imx204 *priv,
			      const imx204_reg table[])
	int cnt = 0;
	int status = 0;
	while (table[cnt].addr != IMX204_TABLE_END) {
		if (table[cnt].addr == IMX204_TABLE_WAIT_MS) {
			msleep_range(table[cnt].val);
		} else {
			status = imx204_write_reg32(priv->s_data,
					table[cnt].addr, table[cnt].val);
			if (status < 0) {
				dev_err(priv->dev, "REG0x%X=0x%X ERROR = %d\n",
						table[cnt].addr,
						table[cnt].val,
						status);
				return status;
		cnt++;
	return status;
static void imx204_gpio_set(struct imx204 *priv,
			    unsigned int gpio, int val)
	if (gpio_cansleep(gpio))
		gpio_set_value_cansleep(gpio, val);
	else
		gpio_set_value(gpio, val);
static int imx204_power_on(struct camera_common_data *s_data)
	struct camera_common_power_rail *pw = &priv->power;
	if (gpio_is_valid(pw->reset_gpio))
		imx204_gpio_set(priv, pw->reset_gpio, 1);
	pw->state = SWITCH_ON;
	return 0;
static int imx204_power_off(struct camera_common_data *s_data)
		imx204_gpio_set(priv, pw->reset_gpio, 0);
	pw->state = SWITCH_OFF;
	return 0;
static int imx204_power_put(struct imx204 *priv)
		gpio_free(pw->reset_gpio);
	return 0;
static int imx204_power_get(struct imx204 *priv)
	struct camera_common_pdata *pdata = priv->pdata;
	int ret = 0;
	pw->reset_gpio = pdata->reset_gpio;
	if (gpio_is_valid(pw->reset_gpio)) {
		ret = gpio_request(pw->reset_gpio, "cam_reset_gpio");
		if (ret < 0) {
			dev_dbg(priv->dev, "%s can't request reset_gpio %d\n",
			__func__, ret);
	return 0;
static int imx204_get_framesync(struct camera_common_data *s_data,
		struct camera_common_framesync *vshs)
	vshs->inck = 72000;
	vshs->xhs = 300;
	vshs->xvs = 4004;
	vshs->fps = 59940;
	return 0;
static int imx204_set_gain(struct imx204 *priv, s32 val);
static int imx204_set_frame_length(struct imx204 *priv, s32 val);
static int imx204_set_coarse_time(struct imx204 *priv, s32 val);
static int imx204_s_stream(struct v4l2_subdev *sd, int enable)
	struct camera_common_data *s_data = to_camera_common_data(sd->dev);
	struct v4l2_control control;
	int err;
	int sensor_mode = s_data->mode;
	dev_dbg(priv->dev, "%s++ enable = %d\n", __func__, enable);
	if (!enable) {
		return imx204_write_table(priv,
			mode_table[IMX204_MODE_STOP_STREAM]);
	err = imx204_write_table(priv, mode_table[sensor_mode]);
	if (err)
		goto exit;
	if (s_data->override_enable) {
		 * write list of override regs for the asking frame length,
		 * coarse integration time, and gain. Failures to write
		 * overrides are non-fatal
		control.id = TEGRA_CAMERA_CID_GAIN;
		err = v4l2_g_ctrl(&priv->ctrl_handler, &control);
		err |= imx204_set_gain(priv, control.value);
		if (err)
			dev_dbg(priv->dev, "%s: warning gain override failed\n",
				__func__);
		control.id = TEGRA_CAMERA_CID_FRAME_LENGTH;
		err |= imx204_set_frame_length(priv, control.value);
		if (err)
			dev_dbg(priv->dev,
				"%s: warning frame length override failed\n",
				__func__);
		control.id = TEGRA_CAMERA_CID_COARSE_TIME;
		err |= imx204_set_coarse_time(priv, control.value);
		if (err)
			dev_dbg(priv->dev,
				"%s: warning coarse time override failed\n",
				__func__);
	if (tegra_platform_is_silicon()) {
				mode_table[IMX204_MODE_START_STREAM]);
		if (err)
			goto exit;
	dev_dbg(priv->dev, "%s--\n", __func__);
	return 0;
exit:
	dev_info(priv->dev, "%s: error setting stream\n", __func__);
	return err;
static int imx204_g_input_status(struct v4l2_subdev *sd, u32 *status)
	*status = pw->state == SWITCH_ON;
	return 0;
static struct v4l2_subdev_video_ops imx204_subdev_video_ops = {
	.s_stream	= imx204_s_stream,
	.g_mbus_config	= camera_common_g_mbus_config,
	.g_input_status = imx204_g_input_status,
static struct v4l2_subdev_core_ops imx204_subdev_core_ops = {
	.s_power	= camera_common_s_power,
static int imx204_get_fmt(struct v4l2_subdev *sd,
		struct v4l2_subdev_pad_config *cfg,
		struct v4l2_subdev_format *format)
	return camera_common_g_fmt(sd, &format->format);
static int imx204_set_fmt(struct v4l2_subdev *sd,
	int ret;
	if (format->which == V4L2_SUBDEV_FORMAT_TRY)
		ret = camera_common_try_fmt(sd, &format->format);
	else
		ret = camera_common_s_fmt(sd, &format->format);
	return ret;
static struct v4l2_subdev_pad_ops imx204_subdev_pad_ops = {
	.set_fmt = imx204_set_fmt,
	.get_fmt = imx204_get_fmt,
	.enum_mbus_code = camera_common_enum_mbus_code,
	.enum_frame_size	= camera_common_enum_framesizes,
	.enum_frame_interval	= camera_common_enum_frameintervals,
static struct v4l2_subdev_ops imx204_subdev_ops = {
	.core	= &imx204_subdev_core_ops,
	.video	= &imx204_subdev_video_ops,
	.pad	= &imx204_subdev_pad_ops,
static struct of_device_id imx204_of_match[] = {
	{ .compatible = "nvidia,imx204-spi", },
MODULE_DEVICE_TABLE(of, imx204_of_match);
static struct camera_common_sensor_ops imx204_common_ops = {
	.power_on = imx204_power_on,
	.power_off = imx204_power_off,
	.write_reg = imx204_write_reg,
	.read_reg = imx204_read_reg,
	.get_framesync = imx204_get_framesync,
static int imx204_set_group_hold(struct imx204 *priv, s32 val)
	dev_dbg(priv->dev, "%s: Not supported\n", __func__);
	return 0;
	imx204_reg	reg_list[2];
	int err;
	int i = 0;
	u16 gain;
	dev_dbg(priv->dev, "%s: val=%d\n", __func__, val);
	if (val < IMX204_MIN_GAIN)
		val = IMX204_MIN_GAIN;
	else if (val > IMX204_MAX_GAIN)
		val = IMX204_MAX_GAIN;
	gain = 2048 - (2048 * IMX204_MIN_GAIN / val);
	if (gain > 1957)
		gain = 1957;
	imx204_get_gain_reg(reg_list, gain);
	for (i = 0; i < ARRAY_SIZE(reg_list); i++) {
		err = imx204_write_reg32(priv->s_data,
			reg_list[i].addr, reg_list[i].val);
		if (err)
			goto fail;
	return 0;
fail:
	dev_err(priv->dev, "%s: set Gain failed\n", __func__);
	return err;
	struct camera_common_data *s_data = priv->s_data;
	const struct sensor_mode_properties *mode =
		&s_data->sensor_props.sensor_modes[s_data->mode];
	int err;
	u32 frame_length;
	u32 frame_rate;
	int i = 0;
	u32	svr = 0;
	if (val < 0)
		val = IMX204_MIN_FRAME_LENGTH;
	frame_length = (u32)val;
	frame_rate = (u32)(mode->signal_properties.pixel_clock.val /
			(u32)(frame_length *
			mode->image_properties.line_length));
	dev_dbg(priv->dev, "%s: frame_rate = %d, pixel_clock = %lld\n",
			 __func__, frame_rate,
			 mode->signal_properties.pixel_clock.val);
	if (frame_rate >= 60)
		svr = 0;
	else {
		while ((frame_rate) <= ((60 / (svr + 1))))
			svr++;
	imx204_get_svr_regs(reg_list, svr);
		err = imx204_write_reg32(priv->s_data, reg_list[i].addr,
							reg_list[i].val);
		if (err)
			goto fail;
	priv->prevSvr = svr;
	dev_dbg(priv->dev, "%s: fps = %d, svr=%d\n", __func__, frame_rate, svr);
	return 0;
fail:
	dev_info(priv->dev, "%s: frame_length control error\n", __func__);
	return err;
	const struct camera_common_data *s_data = priv->s_data;
	u32 shr, svr, spl, shr_min, shr_max;
	u64 et, req;
	u32 i;
	u32 curXHS;
	int err = 0;
	curXHS = IMX204_CLK_PER_XHS_60FPS;
	req = (u64)val;
	et = (req * mode->image_properties.line_length *
		FIXED_POINT_SCALING_FACTOR)	/
		mode->signal_properties.pixel_clock.val;
	svr = priv->prevSvr;
	spl = IMX204_SPL;
	shr = (IMX204_XHS_PER_XVS * (svr-spl+1)) -
		  (((IMX204_INPUT_CLK * et) - IMX204_CLK_PER_INT_OFFSET) /
			curXHS / FIXED_POINT_SCALING_FACTOR);
	dev_dbg(priv->dev, "%s: before shr=%u\n", __func__, shr);
	shr_min = IMX204_SHR_MIN;
	shr_max = (svr + 1) * IMX204_XHS_PER_XVS - 4;
	if (shr < shr_min)
		shr = shr_min;
	if (shr > shr_max)
		shr = shr_max;
	dev_dbg(priv->dev, "%s: shr=%u, svr=%u, et=%llu\n",
		__func__, shr, svr, et);
	imx204_get_coarse_time_regs(reg_list, shr);
							reg_list[i].val);
		if (err)
			goto fail;
	return 0;
fail:
	dev_info(priv->dev, "%s: coarse_time control error\n", __func__);
	return err;
		container_of(ctrl->handler, struct imx204, ctrl_handler);
	int err = 0;
	if (priv->power.state == SWITCH_OFF)
		return 0;
	switch (ctrl->id) {
	default:
			dev_err(priv->dev, "%s: unknown ctrl id.\n", __func__);
			return -EINVAL;
	return err;
	int err = 0;
		return 0;
	switch (ctrl->id) {
	case TEGRA_CAMERA_CID_GAIN:
		err = imx204_set_gain(priv, ctrl->val);
		break;
	case TEGRA_CAMERA_CID_FRAME_LENGTH:
		err = imx204_set_frame_length(priv, ctrl->val);
		break;
	case TEGRA_CAMERA_CID_COARSE_TIME:
		err = imx204_set_coarse_time(priv, ctrl->val);
		break;
	case TEGRA_CAMERA_CID_GROUP_HOLD:
		err = imx204_set_group_hold(priv, ctrl->val);
		break;
	case TEGRA_CAMERA_CID_HDR_EN:
		break;
	default:
		return -EINVAL;
	return err;
static int imx204_ctrls_init(struct imx204 *priv)
	struct v4l2_ctrl *ctrl;
	int num_ctrls;
	int err;
	int i;
	dev_dbg(priv->dev, "%s++\n", __func__);
	num_ctrls = ARRAY_SIZE(ctrl_config_list);
	v4l2_ctrl_handler_init(&priv->ctrl_handler, num_ctrls);
	for (i = 0; i < num_ctrls; i++) {
		ctrl = v4l2_ctrl_new_custom(&priv->ctrl_handler,
			&ctrl_config_list[i], NULL);
		if (ctrl == NULL) {
			dev_err(priv->dev, "Failed to init %s ctrl\n",
				ctrl_config_list[i].name);
			continue;
		if (ctrl_config_list[i].type == V4L2_CTRL_TYPE_STRING &&
			ctrl_config_list[i].flags & V4L2_CTRL_FLAG_READ_ONLY) {
			ctrl->p_new.p_char = devm_kzalloc(priv->dev,
				ctrl_config_list[i].max + 1, GFP_KERNEL);
		priv->ctrls[i] = ctrl;
	priv->num_ctrls = num_ctrls;
	priv->subdev->ctrl_handler = &priv->ctrl_handler;
	if (priv->ctrl_handler.error) {
		dev_err(priv->dev, "Error %d adding controls\n",
			priv->ctrl_handler.error);
		err = priv->ctrl_handler.error;
		goto error;
	err = v4l2_ctrl_handler_setup(&priv->ctrl_handler);
	if (err) {
		dev_err(priv->dev,
			"Error %d setting default controls\n", err);
		goto error;
	return 0;
error:
	v4l2_ctrl_handler_free(&priv->ctrl_handler);
	return err;
static struct camera_common_pdata *imx204_parse_dt(struct spi_device *spi)
	struct device_node *np = spi->dev.of_node;
	struct camera_common_pdata *board_priv_pdata;
	const struct of_device_id *match;
	struct camera_common_pdata *ret = NULL;
	int gpio;
	match = of_match_device(imx204_of_match, &spi->dev);
	if (!match) {
		dev_err(&spi->dev, "Failed to find matching dt id\n");
		return ERR_PTR(-ENODEV);
	board_priv_pdata = devm_kzalloc(&spi->dev,
			   sizeof(*board_priv_pdata), GFP_KERNEL);
	if (!board_priv_pdata) {
		dev_err(&spi->dev, "Failed to allocate pdata\n");
	of_property_read_string(np, "mclk", &board_priv_pdata->mclk_name);
	of_property_read_string(np, "avdd-reg",
			&board_priv_pdata->regulators.avdd);
	of_property_read_string(np, "dvdd-reg",
			&board_priv_pdata->regulators.dvdd);
	of_property_read_string(np, "iovdd-reg",
			&board_priv_pdata->regulators.iovdd);
	gpio = of_get_named_gpio(np, "reset-gpios", 0);
	if (gpio < 0) {
		/* reset-gpio is not absolutely needed */
		if (gpio == -EPROBE_DEFER) {
			ret = ERR_PTR(-EPROBE_DEFER);
			goto error;
		dev_dbg(&spi->dev, "reset gpios not in DT\n");
		gpio = 0;
	board_priv_pdata->reset_gpio = (unsigned int)gpio;
	return board_priv_pdata;
error:
	devm_kfree(&spi->dev, board_priv_pdata);
	return ret;
static int imx204_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
	dev_dbg(sd->dev, "%s:\n", __func__);
	return 0;
static const struct v4l2_subdev_internal_ops imx204_subdev_internal_ops = {
	.open = imx204_open,
static const struct media_entity_operations imx204_media_ops = {
	.link_validate = v4l2_subdev_link_validate,
static int imx204_probe(struct spi_device *spi)
	struct camera_common_data *common_data;
	struct imx204 *priv;
	struct device_node *node = spi->dev.of_node;
	int err;
	int ret = 0;
	pr_info("[IMX204]: probing v4l2 sensor.\n");
	if (!IS_ENABLED(CONFIG_OF) || !node)
		return -EINVAL;
	common_data = devm_kzalloc(&spi->dev,
			    sizeof(struct camera_common_data), GFP_KERNEL);
	if (!common_data) {
		dev_err(&spi->dev, "unable to allocate memory!\n");
		return -ENOMEM;
	priv = devm_kzalloc(&spi->dev,
			    sizeof(struct imx204) + sizeof(struct v4l2_ctrl *) *
			    ARRAY_SIZE(ctrl_config_list),
			    GFP_KERNEL);
	if (!priv) {
		return -ENOMEM;
	spi->mode = SPI_MODE_3 | SPI_LSB_FIRST;
	spi->bits_per_word = 8;
	spi->irq = -1;
	err = spi_setup(spi);
	if (err) {
		dev_err(&spi->dev, "unable to setup SPI!\n");
		return err;
	priv->regmap = devm_regmap_init_spi(spi, &sensor_regmap_config);
	if (IS_ERR(priv->regmap)) {
		dev_err(&spi->dev,
			"regmap init failed: %ld\n", PTR_ERR(priv->regmap));
		return -ENODEV;
	priv->pdata = imx204_parse_dt(spi);
	if (!priv->pdata) {
		dev_err(&spi->dev, "unable to get platform data\n");
		return -EFAULT;
	common_data->ops		= &imx204_common_ops;
	common_data->ctrl_handler	= &priv->ctrl_handler;
	common_data->dev		= &spi->dev;
	common_data->frmfmt		= &imx204_frmfmt[0];
	common_data->colorfmt		= camera_common_find_datafmt(
					  IMX204_DEFAULT_DATAFMT);
	common_data->power		= &priv->power;
	common_data->ctrls		= priv->ctrls;
	common_data->priv		= (void *)priv;
	common_data->numctrls		= ARRAY_SIZE(ctrl_config_list);
	common_data->numfmts		= ARRAY_SIZE(imx204_frmfmt);
	common_data->def_mode		= IMX204_DEFAULT_MODE;
	common_data->def_width		= IMX204_DEFAULT_WIDTH;
	common_data->def_height		= IMX204_DEFAULT_HEIGHT;
	common_data->fmt_width		= common_data->def_width;
	common_data->fmt_height		= common_data->def_height;
	common_data->def_clk_freq	= IMX204_DEFAULT_CLK_FREQ;
	priv->dev				= &spi->dev;
	priv->s_data			= common_data;
	priv->subdev			= &common_data->subdev;
	priv->subdev->dev		= &spi->dev;
	priv->s_data->dev		= &spi->dev;
	priv->spi				= spi;
	err = imx204_power_get(priv);
	if (err)
		return err;
	err = camera_common_initialize(common_data, "imx204");
	if (err)
		return err;
	v4l2_spi_subdev_init(&common_data->subdev, spi, &imx204_subdev_ops);
	err = imx204_ctrls_init(priv);
	if (err)
		return err;
	priv->subdev->internal_ops = &imx204_subdev_internal_ops;
	priv->subdev->flags |= V4L2_SUBDEV_FL_HAS_DEVNODE |
		V4L2_SUBDEV_FL_HAS_EVENTS;
#if defined(CONFIG_MEDIA_CONTROLLER)
	priv->pad.flags = MEDIA_PAD_FL_SOURCE;
	priv->subdev->entity.ops = &imx204_media_ops;
	err = tegra_media_entity_init(&priv->subdev->entity, 1,
				&priv->pad, true, true);
	if (err < 0) {
		dev_err(&spi->dev, "unable to init media entity\n");
		return err;
#endif
	err = v4l2_async_register_subdev(priv->subdev);
	if (err)
		return err;
	pr_info("[IMX204]: probing v4l2 sensor done\n");
	return ret;
static int
imx204_remove(struct spi_device *spi)
	struct camera_common_data *s_data = to_camera_common_data(&spi->dev);
	v4l2_async_unregister_subdev(priv->subdev);
	media_entity_cleanup(&priv->subdev->entity);
#endif
	imx204_power_put(priv);
	camera_common_cleanup(s_data);
	return 0;
static const struct spi_device_id imx204_id[] = {
	{ "imx204", 0 },
MODULE_DEVICE_TABLE(spi, imx204_id);
static struct spi_driver imx204_spi_driver = {
	.driver = {
		.name = "imx204_spi",
		.owner = THIS_MODULE,
		.of_match_table = imx204_of_match,
	.probe = imx204_probe,
	.remove = imx204_remove,
	.id_table = imx204_id,
module_spi_driver(imx204_spi_driver);
MODULE_DESCRIPTION("SPI driver for Sony IMX204");
MODULE_AUTHOR("Frank Chen<frankc@nvidia.com>");
MODULE_LICENSE("GPL v2");
Thanks very much!
