I think one needs to tread carefully here with terminology. GPUs do not use a strict load/store architecture. Various GPU instructions allow one of their source operands to be a constant bank memory location, making these load-execute type of instructions. This deviation from a strict load/store architecture allows GPUS to be more efficient than RISC processor architectures in various practically relevant use cases.
Below is the disassembly of a kernel. The references to c[0x0] represent constant memory locations in .param space, i.e. kernel arguments. The references to c[0x2] are references to the constant memory bank used by the compiler (these come from literal constants in the source code). From the disassembly we can also see that various instructions allow the storage of data inside the instruction itself (immediate data).
/* 0x001c7c00e22007f6 */
/*0008*/ MOV R1, c[0x0][0x20]; /* 0x4c98078000870001 */
/*0010*/ S2R R0, SR_CTAID.X; /* 0xf0c8000002570000 */
/*0018*/ S2R R2, SR_TID.X; /* 0xf0c8000002170002 */
/* 0x001fd840fec20ff1 */
/*0028*/ XMAD.MRG R3, R0.reuse, c[0x0] [0x8].H1, RZ; /* 0x4f107f8000270003 */
/*0030*/ XMAD R2, R0.reuse, c[0x0] [0x8], R2; /* 0x4e00010000270002 */
/*0038*/ XMAD.PSL.CBCC R0, R0.H1, R3.H1, R2; /* 0x5b30011800370000 */
/* 0x081fc400ffa007ed */
/*0048*/ ISETP.GE.AND P0, PT, R0, c[0x0][0x150], PT; /* 0x4b6d038005470007 */
/*0050*/ @P0 EXIT; /* 0xe30000000000000f */
/*0058*/ SHL R2, R0.reuse, 0x2; /* 0x3848000000270002 */
/* 0x001fc800fec007f5 */
/*0068*/ SHR R3, R0, 0x1e; /* 0x3829000001e70003 */
/*0070*/ IADD R2.CC, R2, c[0x0][0x140]; /* 0x4c10800005070202 */
/*0078*/ IADD.X R3, R3, c[0x0][0x144]; /* 0x4c10080005170303 */
/* 0x001fd800fc200071 */
/*0088*/ LDG.E.CI R4, [R2]; /* 0xeed4a00000070204 */
/*0090*/ MOV32I R7, 0x3e2c7e60; /* 0x0103e2c7e607f007 */
/*0098*/ MOV R9, c[0x0][0x8]; /* 0x4c98078000270009 */
/* 0x001fd808fda007f1 */
/*00a8*/ XMAD.MRG R8, R9, c[0x0] [0x14].H1, RZ; /* 0x4f107f8000570908 */
/*00b0*/ FSETP.LT.AND P0, PT, R4, 1.1754943508222875e-038, PT; /* 0x36b1038080070407 */
/*00b8*/ @P0 FMUL R4, R4, 8388608; /* 0x3868004b00000404 */
/* 0x001f9800fec207f6 */
/*00c8*/ IADD32I R5, R4.reuse, -0x3f3504f3; /* 0x1c0c0cafb0d70405 */
/*00d0*/ LOP32I.AND R5, R5, 0xff800000; /* 0x040ff80000070505 */
/*00d8*/ IADD R6, R4, -R5; /* 0x5c11000000570406 */
/* 0x081fd840fec007f6 */
/*00e8*/ FADD R6, R6, -1; /* 0x3958003f80070606 */
/*00f0*/ FFMA R7, R6.reuse, 0.0970458984375, -R7; /* 0x328203bdc6c70607 */
/*00f8*/ FFMA R7, R6.reuse, R7, c[0x2][0x4]; /* 0x5180038800170607 */
/* 0x001f9840fec207f6 */
/*0108*/ FFMA R3, R6.reuse, R7, c[0x2][0x8]; /* 0x5180038800270603 */
/*0110*/ FFMA R3, R6.reuse, R3, c[0x2][0xc]; /* 0x5180018800370603 */
/*0118*/ FFMA R3, R6, R3, c[0x2][0x10]; /* 0x5180018800470603 */
/* 0x081fc440fec007fd */
/*0128*/ FFMA R3, R6, R3, c[0x2][0x14]; /* 0x5180018800570603 */
/*0130*/ FFMA R3, R6.reuse, R3, c[0x2][0x18]; /* 0x5180018800670603 */
/*0138*/ FFMA R3, R6.reuse, R3, c[0x2][0x1c]; /* 0x5180018800770603 */
/* 0x0000c440fe0007f5 */
/*0148*/ FSETP.GEU.AND P1, PT, R4, +INF , PT; /* 0x36be03ff8007040f */
/*0150*/ { FFMA R7, R6.reuse, R3, c[0x2][0x20]; /* 0x5180018800870607 */
/*0158*/ I2F.F32.S32 R3, R5; } /* 0x5cb8000000572a03 */
/* 0x001fc401fc4007f5 */
/*0168*/ SEL R2, RZ, c[0x2][0x0], !P0; /* 0x4ca004080007ff02 */
/*0170*/ FMUL R5, R6, R7; /* 0x5c68000000770605 */
/*0178*/ FSETP.LEU.OR P0, PT, R4, RZ, P1; /* 0x5bbb20800ff70407 */
/* 0x005fd440fe2207f3 */
/*0188*/ XMAD R7, R9.reuse, c[0x0] [0x14], R0; /* 0x4e00000000570907 */
/*0190*/ FMUL R5, R6.reuse, R5; /* 0x5c68000000570605 */
/*0198*/ FFMA R2, R3, 1.1920928955078125e-007, R2; /* 0x3280013400070302 */
/* 0x001fc800fca007f1 */
/*01a8*/ FFMA R3, R6, c[0x2][0x24], R5; /* 0x4980028800970603 */
/*01b0*/ XMAD.PSL.CBCC R6, R9.H1, R8.H1, R7; /* 0x5b30039800870906 */
/*01b8*/ FADD R5, R2, R3; /* 0x5c58000000370205 */
/* 0x081fc400fe200032 */
/*01c8*/ @P0 MUFU.LG2 R5, R4; /* 0x5080000000300405 */
/*01d0*/ ISETP.LT.AND P0, PT, R6, c[0x0][0x150], PT; /* 0x4b63038005470607 */
/*01d8*/ SHR R3, R0.reuse, 0x1f; /* 0x3829000001f70003 */
/* 0x001fc000fc4207f6 */
/*01e8*/ LEA R2.CC, R0.reuse, c[0x0][0x148], 0x2; /* 0x4bd7810005270002 */
/*01f0*/ LEA.HI.X R3, R0, c[0x0][0x14c], R3, 0x2; /* 0x1a17018005370003 */
/*01f8*/ { MOV R0, R6; /* 0x5c98078000670000 */
/*0208*/ STG.E [R2], R5; } /* 0x001ffc01ffa010fd */
/* 0xeedc200000070205 */
/*0210*/ @P0 BRA 0x58; /* 0xe2400fffe400000f */
/*0218*/ EXIT; /* 0xe30000000007000f */
/* 0x001f8000fc0007ff */
/*0228*/ BRA 0x220; /* 0xe2400fffff07000f */
/*0230*/ NOP; /* 0x50b0000000070f00 */
/*0238*/ NOP; /* 0x50b0000000070f00 */
