Where is _build folder?
There are multiple references to a _build folder, e.g. " Unfortunately folder linked scripts are not properly recognized in this setup, so you must add your breakpoints in the real source files, which can be found under the _build folder."
However, when following the steps for creating a new extension with the hello template, it doesn’t create a _build folder (and I can’t find it when searching the kit app). Where is it located?
https://docs.omniverse.nvidia.com/py/kit/docs/guide/faq.html
Hello @user56551! I asked for more information from the development team about the _build folder. I will post back when I have more information to share!
