I can see in deepstream-app:
if (g_strrstr (name, "nvcuvid") == name) {
g_object_set (object, "gpu-id", config->gpu_id, NULL);
g_object_set (G_OBJECT (object), "cuda-memory-type",
config->cuda_memory_type, NULL);
g_object_set (object, "source-id", config->camera_id, NULL);
g_object_set (object, "num-decode-surfaces", config->num_decode_surfaces,
NULL);
if (config->Intra_decode)
g_object_set (object, "Intra-decode", config->Intra_decode, NULL);
But when I use
gst-inspect-1.0 nvcuvid
why there is not any plugins name “nvcuvid” ?
