there are lots of included dtsi, who knows which one contains its PCIe property node in the device tree? the purpose is that I want to disable pcie root complex property node.
Hi
The source code structure is as below:
hardware → soc → this means general property of each soc. T194 is for Xavier series. T234 is for Orin.
hardware → platform → this is for each platform. For example, Orin AGX is concord. Xavier NX is jakku.
The device tree in “platform” will include the dtsi files in “soc”. There will be only one file get flashed to the board.
Thus, you can add change in any place in the whole “include” path. There is no precise answer for your question.
do you know if Xaxvier and Orin has have overlayered “iommus” node property? I searched for key string “iommus”, didn’t find in the T194 and T234 associated dts and dtsi.
And, I raised the question as well in the ARM Linux community, and got the support from Robin, I tried fix this if it is possible, please have a check this mailist:
SR-IOV on ARM64 system with SMMU (kernel.org)
Under which path are you doing this search?
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:123: iommus = <&mc TEGRA_SWGROUP_HC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:138: iommus = <&mc TEGRA_SWGROUP_MPE>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:149: iommus = <&mc TEGRA_SWGROUP_VI>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:160: iommus = <&mc TEGRA_SWGROUP_EPP>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:171: iommus = <&mc TEGRA_SWGROUP_ISP>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:182: iommus = <&mc TEGRA_SWGROUP_G2>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:195: iommus = <&mc TEGRA_SWGROUP_NV>,
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:209: iommus = <&mc TEGRA_SWGROUP_DC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:228: iommus = <&mc TEGRA_SWGROUP_DCB>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra30.dtsi:441: iommus = <&mc TEGRA_SWGROUP_VDE>;
./kernel/kernel-5.10/arch/arm/boot/dts/mt7623n.dtsi:125: iommus = <&iommu MT2701_M4U_PORT_JPGDEC_WDMA>,
./kernel/kernel-5.10/arch/arm/boot/dts/mt7623n.dtsi:146: iommus = <&iommu MT2701_M4U_PORT_DISP_OVL_0>;
./kernel/kernel-5.10/arch/arm/boot/dts/mt7623n.dtsi:156: iommus = <&iommu MT2701_M4U_PORT_DISP_RDMA>;
./kernel/kernel-5.10/arch/arm/boot/dts/mt7623n.dtsi:166: iommus = <&iommu MT2701_M4U_PORT_DISP_WDMA>;
./kernel/kernel-5.10/arch/arm/boot/dts/mt7623n.dtsi:217: iommus = <&iommu MT2701_M4U_PORT_DISP_RDMA1>;
./kernel/kernel-5.10/arch/arm/boot/dts/omap34xx.dtsi:99: iommus = <&mmu_isp>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4412.dtsi:288: iommus = <&sysmmu_g2d>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4412.dtsi:596: iommus = <&sysmmu_fimc_lite0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4412.dtsi:607: iommus = <&sysmmu_fimc_lite1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4412.dtsi:646: iommus = <&sysmmu_fimc_isp>, <&sysmmu_fimc_drc>,
./kernel/kernel-5.10/arch/arm/boot/dts/omap4.dtsi:286: iommus = <&mmu_dsp>;
./kernel/kernel-5.10/arch/arm/boot/dts/omap4.dtsi:298: iommus = <&mmu_ipu>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4210.dtsi:168: iommus = <&sysmmu_g2d>;
./kernel/kernel-5.10/arch/arm/boot/dts/dra74x.dtsi:119: iommus = <&mmu0_dsp2>, <&mmu1_dsp2>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos3250.dtsi:302: iommus = <&sysmmu_jpeg>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos3250.dtsi:326: iommus = <&sysmmu_fimd0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos3250.dtsi:487: iommus = <&sysmmu_mfc>;
./kernel/kernel-5.10/arch/arm/boot/dts/rk322x.dtsi:592: iommus = <&vop_mmu>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:200: iommus = <&sysmmu_mfc_l>, <&sysmmu_mfc_r>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:706: iommus = <&sysmmu_tv>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:716: iommus = <&sysmmu_rotator>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:726: iommus = <&sysmmu_gscl0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:736: iommus = <&sysmmu_gscl1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:796: iommus = <&sysmmu_scaler0r>, <&sysmmu_scaler0w>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:806: iommus = <&sysmmu_scaler1r>, <&sysmmu_scaler1w>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:816: iommus = <&sysmmu_scaler2r>, <&sysmmu_scaler2w>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:825: iommus = <&sysmmu_jpeg0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:834: iommus = <&sysmmu_jpeg1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:1239: iommus = <&sysmmu_fimd1_0>, <&sysmmu_fimd1_1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5420.dtsi:1244: iommus = <&sysmmu_g2dr>, <&sysmmu_g2dw>;
./kernel/kernel-5.10/arch/arm/boot/dts/rk3288.dtsi:1048: iommus = <&vopb_mmu>;
./kernel/kernel-5.10/arch/arm/boot/dts/rk3288.dtsi:1098: iommus = <&vopl_mmu>;
./kernel/kernel-5.10/arch/arm/boot/dts/rk3288.dtsi:1266: iommus = <&vpu_mmu>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra114.dtsi:30: iommus = <&mc TEGRA_SWGROUP_HC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra114.dtsi:45: iommus = <&mc TEGRA_SWGROUP_G2>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra114.dtsi:55: iommus = <&mc TEGRA_SWGROUP_NV>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra114.dtsi:68: iommus = <&mc TEGRA_SWGROUP_DC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra114.dtsi:87: iommus = <&mc TEGRA_SWGROUP_DCB>;
./kernel/kernel-5.10/arch/arm/boot/dts/qcom-apq8064.dtsi:1167: iommus = <&gfx3d 0
./kernel/kernel-5.10/arch/arm/boot/dts/qcom-apq8064.dtsi:1476: iommus = <&mdp_port0 0
./kernel/kernel-5.10/arch/arm/boot/dts/omap5.dtsi:229: iommus = <&mmu_dsp>;
./kernel/kernel-5.10/arch/arm/boot/dts/omap5.dtsi:241: iommus = <&mmu_ipu>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra124.dtsi:97: iommus = <&mc TEGRA_SWGROUP_HC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra124.dtsi:113: iommus = <&mc TEGRA_SWGROUP_DC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra124.dtsi:127: iommus = <&mc TEGRA_SWGROUP_DCB>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra124.dtsi:153: iommus = <&mc TEGRA_SWGROUP_VIC>;
./kernel/kernel-5.10/arch/arm/boot/dts/tegra124.dtsi:220: iommus = <&mc TEGRA_SWGROUP_GPU>;
./kernel/kernel-5.10/arch/arm/boot/dts/mt2701.dtsi:568: iommus = <&iommu MT2701_M4U_PORT_JPGDEC_WDMA>,
./kernel/kernel-5.10/arch/arm/boot/dts/mt2701.dtsi:581: iommus = <&iommu MT2701_M4U_PORT_JPGENC_RDMA>,
./kernel/kernel-5.10/arch/arm/boot/dts/dra7.dtsi:418: iommus = <&mmu_ipu1>;
./kernel/kernel-5.10/arch/arm/boot/dts/dra7.dtsi:429: iommus = <&mmu_ipu2>;
./kernel/kernel-5.10/arch/arm/boot/dts/dra7.dtsi:443: iommus = <&mmu0_dsp1>, <&mmu1_dsp1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:307: iommus = <&sysmmu_mfc_l>, <&sysmmu_mfc_r>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:317: iommus = <&sysmmu_rotator>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:739: iommus = <&sysmmu_gsc0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:749: iommus = <&sysmmu_gsc1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:759: iommus = <&sysmmu_gsc2>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:769: iommus = <&sysmmu_gsc3>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:809: iommus = <&sysmmu_tv>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:1139: iommus = <&sysmmu_fimd1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos5250.dtsi:1143: iommus = <&sysmmu_g2d>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:223: iommus = <&sysmmu_fimc0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:236: iommus = <&sysmmu_fimc1>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:249: iommus = <&sysmmu_fimc2>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:262: iommus = <&sysmmu_fimc3>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:445: iommus = <&sysmmu_mfc_l>, <&sysmmu_mfc_r>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:714: iommus = <&sysmmu_fimd0>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:734: iommus = <&sysmmu_jpeg>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:743: iommus = <&sysmmu_rotator>;
./kernel/kernel-5.10/arch/arm/boot/dts/exynos4.dtsi:781: iommus = <&sysmmu_tv>;
./kernel/kernel-5.10/arch/arm/boot/dts/omap36xx.dtsi:132: iommus = <&mmu_isp>;
./kernel/kernel-5.10/arch/arm/boot/dts/rk3036.dtsi:145: iommus = <&vop_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/broadcom/stingray/stingray.dtsi:570: iommus = <&smmu 0x6000 0x0000>;
./kernel/kernel-5.10/arch/arm64/boot/dts/broadcom/stingray/stingray.dtsi:601: iommus = <&smmu 0x6002 0x0000>;
./kernel/kernel-5.10/arch/arm64/boot/dts/broadcom/stingray/stingray.dtsi:611: iommus = <&smmu 0x6003 0x0000>;
./kernel/kernel-5.10/arch/arm64/boot/dts/intel/socfpga_agilex.dtsi:150: iommus = <&smmu 1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/intel/socfpga_agilex.dtsi:168: iommus = <&smmu 2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/intel/socfpga_agilex.dtsi:186: iommus = <&smmu 3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/intel/socfpga_agilex.dtsi:300: iommus = <&smmu 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/intel/socfpga_agilex.dtsi:487: iommus = <&smmu 6>;
./kernel/kernel-5.10/arch/arm64/boot/dts/intel/socfpga_agilex.dtsi:499: iommus = <&smmu 7>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:944: iommus = <&iommu M4U_PORT_MDP_RDMA0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:955: iommus = <&iommu M4U_PORT_MDP_RDMA1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:985: iommus = <&iommu M4U_PORT_MDP_WDMA>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:994: iommus = <&iommu M4U_PORT_MDP_WROT0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1003: iommus = <&iommu M4U_PORT_MDP_WROT1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1013: iommus = <&iommu M4U_PORT_DISP_OVL0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1024: iommus = <&iommu M4U_PORT_DISP_OVL1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1035: iommus = <&iommu M4U_PORT_DISP_RDMA0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1046: iommus = <&iommu M4U_PORT_DISP_RDMA1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1057: iommus = <&iommu M4U_PORT_DISP_RDMA2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1068: iommus = <&iommu M4U_PORT_DISP_WDMA0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1079: iommus = <&iommu M4U_PORT_DISP_WDMA1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1332: iommus = <&iommu M4U_PORT_HW_VDEC_MC_EXT>,
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1403: iommus = <&iommu M4U_PORT_VENC_RCPU>,
./kernel/kernel-5.10/arch/arm64/boot/dts/mediatek/mt8173.dtsi:1448: iommus = <&iommu M4U_PORT_JPGDEC_WDMA>,
./kernel/kernel-5.10/arch/arm64/boot/dts/hisilicon/hip07.dtsi:1742: iommus = <&p0_smmu_alg_a 0x600>;
./kernel/kernel-5.10/arch/arm64/boot/dts/hisilicon/hip07.dtsi:1783: iommus = <&p0_smmu_alg_b 0x600>;
./kernel/kernel-5.10/arch/arm64/boot/dts/hisilicon/hip07.dtsi:1824: iommus = <&p1_smmu_alg_a 0x600>;
./kernel/kernel-5.10/arch/arm64/boot/dts/hisilicon/hip07.dtsi:1865: iommus = <&p1_smmu_alg_b 0x600>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sm8150.dtsi:624: iommus = <&adreno_smmu 0 0x401>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sm8150.dtsi:693: iommus = <&adreno_smmu 5 0x400>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8998.dtsi:2111: iommus = <&anoc2_smmu 0x1900>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sm8250.dtsi:1260: iommus = <&adreno_smmu 0 0x401>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sm8250.dtsi:1335: iommus = <&adreno_smmu 5 0x400>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8916.dtsi:926: iommus = <&apps_iommu 4>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8916.dtsi:1080: iommus = <&apps_iommu 3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8916.dtsi:1137: iommus = <&gpu_iommu 1>, <&gpu_iommu 2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8916.dtsi:1160: iommus = <&apps_iommu 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:686: iommus = <&apps_smmu 0x60 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:758: iommus = <&apps_smmu 0x43 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:1049: iommus = <&apps_smmu 0x4c3 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:1397: iommus = <&apps_smmu 0x440 0x0>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:1907: iommus = <&adreno_smmu 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:1999: iommus = <&adreno_smmu 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:2162: iommus = <&apps_smmu 0x04a0 0x20>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:2519: iommus = <&apps_smmu 0x80 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:2710: iommus = <&apps_smmu 0x540 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:2735: iommus = <&apps_smmu 0x0c00 0x60>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:2818: iommus = <&apps_smmu 0x800 0x2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180.dtsi:3361: iommus = <&apps_smmu 0xc0 0x1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180-idp.dts:320: iommus = <&apps_smmu 0x461 0x0>, <&apps_smmu 0x444 0x3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180-idp.dts:399: iommus = <&apps_smmu 0x0c42 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180-idp.dts:411: iommus = <&apps_smmu 0xc2 0x1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845-cheza.dtsi:637: iommus = <&apps_smmu 0x781 0x0>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845-cheza.dtsi:1314: iommus = <&apps_smmu 0x10b2 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8996.dtsi:543: iommus = <&mdp_smmu 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8996.dtsi:643: iommus = <&adreno_smmu 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8996.dtsi:1083: iommus = <&vfe_smmu 0>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8996.dtsi:1158: iommus = <&venus_smmu 0x00>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/msm8996.dtsi:2107: iommus = <&lpass_q6_smmu 1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:817: iommus = <&apps_smmu 0x1821 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:842: iommus = <&apps_smmu 0x1823 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:848: iommus = <&apps_smmu 0x1824 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:890: iommus = <&apps_smmu 0x1401 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:896: iommus = <&apps_smmu 0x1402 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:902: iommus = <&apps_smmu 0x1403 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:908: iommus = <&apps_smmu 0x1404 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:914: iommus = <&apps_smmu 0x1405 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:920: iommus = <&apps_smmu 0x1406 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:926: iommus = <&apps_smmu 0x1407 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:932: iommus = <&apps_smmu 0x1408 0x30>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:1846: iommus = <&apps_smmu 0x1c10 0xf>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:1955: iommus = <&apps_smmu 0x1c00 0xf>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:2080: iommus = <&apps_smmu 0x100 0xf>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:2144: iommus = <&apps_smmu 0x720 0x0>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:3300: iommus = <&apps_smmu 0xa0 0xf>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:3381: iommus = <&apps_smmu 0x1806 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:3586: iommus = <&apps_smmu 0x740 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:3634: iommus = <&apps_smmu 0x760 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:3662: iommus = <&apps_smmu 0x10a0 0x8>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:3826: iommus = <&apps_smmu 0x880 0x8>,
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:4050: iommus = <&adreno_smmu 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:4150: iommus = <&adreno_smmu 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:4497: iommus = <&apps_smmu 0x1806 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sdm845.dtsi:4600: iommus = <&apps_smmu 0x0040 0x1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180-trogdor.dtsi:753: iommus = <&apps_smmu 0x461 0x0>, <&apps_smmu 0x444 0x3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180-trogdor.dtsi:850: iommus = <&apps_smmu 0x0c42 0x0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/qcom/sc7180-trogdor.dtsi:863: iommus = <&apps_smmu 0xc2 0x1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:202: iommus = <&smmu_etr 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:512: /* iommus = <&smmu_gpu 0>; */
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:689: iommus = <&smmu_dma 0>,
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:706: iommus = <&smmu_hdlcd1 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:721: iommus = <&smmu_hdlcd0 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:775: iommus = <&smmu_usb 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/arm/juno-base.dtsi:783: iommus = <&smmu_usb 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:139: iommus = <&iommu 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/allwinner/sun50i-h6.dtsi:165: iommus = <&iommu 3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:875: iommus = <&sysmmu_decon0x>, <&sysmmu_decon1x>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:918: iommus = <&sysmmu_tv0x>, <&sysmmu_tv1x>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1043: iommus = <&sysmmu_gscl0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1058: iommus = <&sysmmu_gscl1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1073: iommus = <&sysmmu_gscl2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1136: iommus = <&sysmmu_scaler_0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1148: iommus = <&sysmmu_scaler_1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1161: iommus = <&sysmmu_jpeg>;
./kernel/kernel-5.10/arch/arm64/boot/dts/exynos/exynos5433.dtsi:1173: iommus = <&sysmmu_mfc_0>, <&sysmmu_mfc_1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi:153: iommus = <&smmu 1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi:171: iommus = <&smmu 2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi:189: iommus = <&smmu 3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi:301: iommus = <&smmu 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi:487: iommus = <&smmu 6>;
./kernel/kernel-5.10/arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi:500: iommus = <&smmu 7>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/rk3328.dtsi:655: iommus = <&vpu_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/rk3328.dtsi:689: iommus = <&vop_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/px30.dtsi:1036: iommus = <&vopb_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/px30.dtsi:1077: iommus = <&vopl_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/rk3399.dtsi:1262: iommus = <&vpu_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/rk3399.dtsi:1284: iommus = <&vdec_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/rk3399.dtsi:1622: iommus = <&vopl_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/rockchip/rk3399.dtsi:1679: iommus = <&vopb_mmu>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:36: iommus = <&smmu 0x444>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:40: iommus = <&smmu 0x445>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:44: iommus = <&smmu 0x440>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:48: iommus = <&smmu 0x441>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:52: iommus = <&smmu 0x454>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:56: iommus = <&smmu 0x450>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-8040.dtsi:60: iommus = <&smmu 0x451>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-7040.dtsi:27: iommus = <&smmu 0x444>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-7040.dtsi:31: iommus = <&smmu 0x445>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-7040.dtsi:35: iommus = <&smmu 0x440>;
./kernel/kernel-5.10/arch/arm64/boot/dts/marvell/armada-7040.dtsi:39: iommus = <&smmu 0x441>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:982: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:1024: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:1066: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:1253: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2374: iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2416: iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2602: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2615: iommus = <&ipmmu_ds1 33>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2628: iommus = <&ipmmu_ds1 34>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2641: iommus = <&ipmmu_ds1 35>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2654: iommus = <&ipmmu_hc 2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2871: iommus = <&ipmmu_vp0 0>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2880: iommus = <&ipmmu_vp1 1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2889: iommus = <&ipmmu_vp0 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2898: iommus = <&ipmmu_vp1 7>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2907: iommus = <&ipmmu_vp0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2916: iommus = <&ipmmu_vp1 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2925: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2934: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77951.dtsi:2943: iommus = <&ipmmu_vi1 10>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:448: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:476: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:504: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:631: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:928: iommus = <&ipmmu_ds1 34>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:985: iommus = <&ipmmu_vp0 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:994: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77995.dtsi:1003: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77980.dtsi:670: iommus = <&ipmmu_ds1 33>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77980.dtsi:1205: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77980.dtsi:1247: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77980.dtsi:1343: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:907: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:949: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:991: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:1130: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2251: iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2293: iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2407: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2420: iommus = <&ipmmu_ds1 33>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2433: iommus = <&ipmmu_ds1 34>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2446: iommus = <&ipmmu_ds1 35>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2573: iommus = <&ipmmu_vc0 19>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2582: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2591: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77960.dtsi:2600: iommus = <&ipmmu_vi0 10>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77970.dtsi:618: iommus = <&ipmmu_rt 3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77970.dtsi:954: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77970.dtsi:982: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77970.dtsi:1038: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:726: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:768: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:810: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:941: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1648: iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1726: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1739: iommus = <&ipmmu_ds1 33>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1752: iommus = <&ipmmu_ds1 35>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1816: iommus = <&ipmmu_vp0 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1835: iommus = <&ipmmu_vp0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1854: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77990.dtsi:1873: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77961.dtsi:1670: iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77961.dtsi:1712: iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77961.dtsi:1958: iommus = <&ipmmu_vc0 19>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77961.dtsi:1967: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77961.dtsi:1976: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77961.dtsi:1985: iommus = <&ipmmu_vi0 10>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:756: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:798: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:840: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:964: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:1552: iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:1766: iommus = <&ipmmu_vp0 5>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:1775: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:1784: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774c0.dtsi:1793: iommus = <&ipmmu_vp0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:981: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:1023: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:1065: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:1238: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2212: iommus = <&ipmmu_mp0 0>, <&ipmmu_mp0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2254: iommus = <&ipmmu_mp0 16>, <&ipmmu_mp0 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2368: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2381: iommus = <&ipmmu_ds1 33>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2394: iommus = <&ipmmu_ds1 34>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2407: iommus = <&ipmmu_ds1 35>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774e1.dtsi:2419: iommus = <&ipmmu_hc 2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:11: iommus = <&ipmmu_mp1 0>, <&ipmmu_mp1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:22: iommus = <&ipmmu_mp1 16>, <&ipmmu_mp1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:37: iommus = <&ipmmu_vp0 7>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:41: iommus = <&ipmmu_vp0 1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:45: iommus = <&ipmmu_vp0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:49: iommus = <&ipmmu_vi0 10>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:134: iommus = <&ipmmu_vp0 2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:143: iommus = <&ipmmu_vi0 11>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77950.dtsi:152: iommus = <&ipmmu_vp0 10>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:776: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:818: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:860: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:991: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:2132: iommus = <&ipmmu_ds1 32>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:2145: iommus = <&ipmmu_ds1 33>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:2158: iommus = <&ipmmu_ds1 34>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a77965.dtsi:2171: iommus = <&ipmmu_ds1 35>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774b1.dtsi:800: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774b1.dtsi:842: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774b1.dtsi:884: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774b1.dtsi:1009: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:927: iommus = <&ipmmu_ds0 0>, <&ipmmu_ds0 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:969: iommus = <&ipmmu_ds1 0>, <&ipmmu_ds1 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:1011: iommus = <&ipmmu_ds1 16>, <&ipmmu_ds1 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:1136: iommus = <&ipmmu_ds0 16>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:2126: iommus = <&ipmmu_mp 0>, <&ipmmu_mp 1>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:2168: iommus = <&ipmmu_mp 16>, <&ipmmu_mp 17>,
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:2462: iommus = <&ipmmu_vi0 8>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:2471: iommus = <&ipmmu_vi0 9>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:2480: iommus = <&ipmmu_vi0 10>;
./kernel/kernel-5.10/arch/arm64/boot/dts/renesas/r8a774a1.dtsi:2489: iommus = <&ipmmu_vc0 19>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:66: iommus = <&smmu TEGRA186_SID_EQOS>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:563: iommus = <&smmu TEGRA186_SID_SDMMC1>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:593: iommus = <&smmu TEGRA186_SID_SDMMC2>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:618: iommus = <&smmu TEGRA186_SID_SDMMC3>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:648: iommus = <&smmu TEGRA186_SID_SDMMC4>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:679: iommus = <&smmu TEGRA186_SID_HDA>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:809: iommus = <&smmu TEGRA186_SID_XUSB_HOST>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:828: iommus = <&smmu TEGRA186_SID_XUSB_DEV>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1035: iommus = <&smmu TEGRA186_SID_AFI>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1175: iommus = <&smmu TEGRA186_SID_HOST1X>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1249: iommus = <&smmu TEGRA186_SID_NVDISPLAY>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1268: iommus = <&smmu TEGRA186_SID_NVDISPLAY>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1287: iommus = <&smmu TEGRA186_SID_NVDISPLAY>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1322: iommus = <&smmu TEGRA186_SID_VIC>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra186.dtsi:1511: iommus = <&smmu TEGRA186_SID_BPMP>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra132.dtsi:108: iommus = <&mc TEGRA_SWGROUP_DC>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra132.dtsi:122: iommus = <&mc TEGRA_SWGROUP_DCB>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra210.dtsi:104: iommus = <&mc TEGRA_SWGROUP_HC>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra210.dtsi:195: iommus = <&mc TEGRA_SWGROUP_DC>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra210.dtsi:210: iommus = <&mc TEGRA_SWGROUP_DCB>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra210.dtsi:243: iommus = <&mc TEGRA_SWGROUP_VIC>;
./kernel/kernel-5.10/arch/arm64/boot/dts/nvidia/tegra210.dtsi:426: iommus = <&mc TEGRA_SWGROUP_GPU>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:35: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:57: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:79: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:101: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:132: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:152: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:172: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-i2c.dtsi:194: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-sata.dtsi:31: iommus = <&smmu TEGRA_SID_SATA2>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:71: * iommus node are deleted for ISO-Clients which are
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:76: /delete-property/ iommus;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:81: /delete-property/ iommus;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:86: /delete-property/ iommus;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:91: /delete-property/ iommus;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:107: /delete-property/ iommus;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-virt.dtsi:112: /delete-property/ iommus;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:35: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:60: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:81: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:102: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:123: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:144: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:165: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-uart.dtsi:186: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-aon.dtsi:21: iommus = <&smmu TEGRA_SID_AON>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-sdhci.dtsi:37: iommus = <&smmu TEGRA_SID_SDMMC4A>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-sdhci.dtsi:96: iommus = <&smmu TEGRA_SID_SDMMC3A>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-sdhci.dtsi:164: iommus = <&smmu TEGRA_SID_SDMMC1A>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-ufshc.dtsi:42: iommus = <&smmu TEGRA_SID_UFSHC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:533: iommus = <&smmu TEGRA_SID_PCIE0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:601: iommus = <&smmu TEGRA_SID_PCIE4>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:675: iommus = <&smmu TEGRA_SID_PCIE5>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:723: iommus = <&smmu TEGRA_SID_PCIE0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:802: iommus = <&smmu TEGRA_SID_PCIE1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:884: iommus = <&smmu TEGRA_SID_PCIE2>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:964: iommus = <&smmu TEGRA_SID_PCIE3>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:1044: iommus = <&smmu TEGRA_SID_PCIE4>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-pcie.dtsi:1127: iommus = <&smmu TEGRA_SID_PCIE5>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:346: iommus = <&smmu TEGRA_SID_SMMU_TEST>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:355: iommus = <&smmu TEGRA_SID_SMMU_TEST>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:363: iommus = <&smmu_iso TEGRA_SID_SMMU_TEST>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:371: iommus = <&smmu TEGRA_SID_PCIE0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:379: iommus = <&smmu TEGRA_SID_PCIE1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:387: iommus = <&smmu TEGRA_SID_PCIE2>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:395: iommus = <&smmu TEGRA_SID_PCIE3>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:403: iommus = <&smmu TEGRA_SID_PCIE4>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:411: iommus = <&smmu TEGRA_SID_PCIE5>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:419: iommus = <&smmu TEGRA_SID_ISP>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-memory.dtsi:427: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-camera.dtsi:66: iommus = <&smmu TEGRA_SID_RCE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-safety-sce.dtsi:61: iommus = <&smmu TEGRA_SID_SCE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-eqos.dtsi:105: iommus = <&smmu TEGRA_SID_EQOS>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:21: iommus = <&smmu TEGRA_SID_APE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:28: iommus = <&smmu TEGRA_SID_APE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:34: iommus = <&smmu TEGRA_SID_APE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:138: iommus = <&smmu TEGRA_SID_APE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:728: iommus = <&smmu TEGRA_SID_APE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:770: iommus = <&smmu TEGRA_SID_APE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-audio.dtsi:778: iommus = <&smmu TEGRA_SID_HDA>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:431: iommus = <&smmu TEGRA_SID_HC>,
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:456: iommus = <&smmu TEGRA_SID_HOST1X_CTX0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:463: iommus = <&smmu TEGRA_SID_HOST1X_CTX1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:470: iommus = <&smmu TEGRA_SID_HOST1X_CTX2>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:477: iommus = <&smmu TEGRA_SID_HOST1X_CTX3>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:484: iommus = <&smmu TEGRA_SID_HOST1X_CTX4>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:491: iommus = <&smmu TEGRA_SID_HOST1X_CTX5>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:498: iommus = <&smmu TEGRA_SID_HOST1X_CTX6>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:505: iommus = <&smmu TEGRA_SID_HOST1X_CTX7>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:520: iommus = <&smmu TEGRA_SID_VIC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:532: iommus = <&smmu TEGRA_SID_VIC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:544: iommus = <&smmu TEGRA_SID_TSEC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:556: iommus = <&smmu TEGRA_SID_TSECB>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:570: iommus = <&smmu TEGRA_SID_VIC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:584: iommus = <&smmu TEGRA_SID_VIC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:596: iommus = <&smmu TEGRA_SID_VIC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:608: iommus = <&smmu TEGRA_SID_VIC>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:625: iommus = <&smmu TEGRA_SID_NVDLA0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:640: iommus = <&smmu TEGRA_SID_NVDLA1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:660: iommus = <&smmu_iso TEGRA_SID_NVDISPLAY>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:735: iommus = <&smmu_iso TEGRA_SID_NVDISPLAY>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:809: iommus = <&smmu_iso TEGRA_SID_NVDISPLAY>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:883: iommus = <&smmu_iso TEGRA_SID_NVDISPLAY>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1191: iommus = <&smmu_iso TEGRA_SID_VI>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1207: iommus = <&smmu TEGRA_SID_ISP>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1258: iommus = <&smmu TEGRA_SID_PVA0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1275: iommus = <&smmu TEGRA_SID_PVA1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1289: iommus = <&smmu TEGRA_SID_SE>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1305: iommus = <&smmu TEGRA_SID_SE1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1321: iommus = <&smmu TEGRA_SID_SE2>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1337: iommus = <&smmu TEGRA_SID_SE3>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1383: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1826: iommus = <&smmu TEGRA_SID_XUSB_DEV>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1887: iommus = <&smmu TEGRA_SID_XUSB_HOST>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1907: iommus = <&smmu TEGRA_SID_XUSB_VF0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1927: iommus = <&smmu TEGRA_SID_XUSB_VF1>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1947: iommus = <&smmu TEGRA_SID_XUSB_VF2>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-base.dtsi:1967: iommus = <&smmu TEGRA_SID_XUSB_VF3>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-spi.dtsi:32: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-spi.dtsi:53: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-spi.dtsi:74: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-spi.dtsi:95: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t19x/kernel-dts/tegra194-soc/tegra194-soc-spi.dtsi:117: iommus = <&smmu TEGRA_SID_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie-fpga.dtsi:75: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie-fpga.dtsi:160: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-fsicom.dtsi:30: iommus = <&smmu_niso1 TEGRA_SID_NISO1_FSI>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-psc.dtsi:22: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PSC>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-spi.dtsi:32: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-spi.dtsi:53: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-spi.dtsi:74: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-spi.dtsi:95: iommus = <&smmu_niso1 TEGRA_SID_NISO1_QSPI0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-spi.dtsi:116: iommus = <&smmu_niso1 TEGRA_SID_NISO1_QSPI1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-camera.dtsi:58: iommus = <&smmu_niso0 TEGRA_SID_NISO0_RCE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:468: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE5>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:544: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE6>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:620: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE7>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:696: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE10>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:755: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:834: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:914: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:993: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1072: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE4>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1151: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE5>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1231: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE6>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1311: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE7>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1391: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE8>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1471: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE9>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-pcie.dtsi:1551: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE10>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-fpga.dtsi:193: iommus = <&smmu_niso1 TEGRA_SID_NISO1_BPMP>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-fpga.dtsi:469: iommus = <&smmu_iso TEGRA_SID_ISO_NVDISPLAY>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-fpga.dtsi:473: iommus = <&smmu_niso0 TEGRA_SID_NISO0_NVDISPLAY>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-fpga.dtsi:480: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HDA>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-fpga.dtsi:657: iommus = <&smmu_niso0 TEGRA_SID_NISO0_DCE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-sdhci.dtsi:42: iommus = <&smmu_niso1 TEGRA_SID_NISO1_SDMMC4A>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-sdhci.dtsi:100: iommus = <&smmu_niso1 TEGRA_SID_NISO1_SDMMC1A>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-aon.dtsi:21: iommus = <&smmu_niso0 TEGRA_SID_NISO0_AON>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-virt.dtsi:159: * iommus node are deleted for ISO-Clients which are
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-virt.dtsi:162: /delete-property/ iommus;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-virt.dtsi:168: /delete-property/ iommus;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-virt.dtsi:174: /delete-property/ iommus;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-virt.dtsi:180: /delete-property/ iommus;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:21: iommus = <&smmu_niso0 TEGRA_SID_NISO0_SMMU_TEST>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:29: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:38: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:47: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:56: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:65: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE4>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:74: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE5>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:83: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE6>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:92: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE7>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:101: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE8>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:110: iommus = <&smmu_niso0 TEGRA_SID_NISO0_PCIE9>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:119: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PCIE10>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:127: iommus = <&smmu_niso1 TEGRA_SID_NISO1_ISP>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:140: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:148: iommus = <&smmu_niso1 TEGRA_SID_NISO1_QSPI0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mods.dtsi:156: iommus = <&smmu_niso1 TEGRA_SID_NISO1_QSPI1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:58: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HC>,
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:78: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:85: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:92: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:99: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:106: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX4>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:113: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX5>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:120: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX6>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:127: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HOST1X_CTX7>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:134: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:141: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:148: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:155: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:162: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX4>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:169: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX5>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:176: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX6>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:183: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HOST1X_CTX7>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:203: iommus = <&smmu_niso1 TEGRA_SID_NISO1_VIC>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:216: iommus = <&smmu_niso1 TEGRA_SID_NISO1_NVJPG>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:229: iommus = <&smmu_niso0 TEGRA_SID_NISO0_NVJPG1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:244: iommus = <&smmu_niso1 TEGRA_SID_NISO1_TSEC>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:260: iommus = <&smmu_niso1 TEGRA_SID_NISO1_NVDEC>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:273: iommus = <&smmu_niso0 TEGRA_SID_NISO0_NVENC>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:286: iommus = <&smmu_niso0 TEGRA_SID_NISO0_OFA>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:297: iommus = <&smmu_iso TEGRA_SID_ISO_VI>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:313: iommus = <&smmu_iso TEGRA_SID_ISO_VI2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:334: iommus = <&smmu_niso1 TEGRA_SID_NISO1_ISP>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:371: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:377: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:384: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:391: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:398: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:405: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM4>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:412: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM5>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:419: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM6>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:426: iommus = <&smmu_niso1 TEGRA_SID_NISO1_PVA0_VM7>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:443: iommus = <&smmu_niso1 TEGRA_SID_NISO1_NVDLA0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:459: iommus = <&smmu_niso0 TEGRA_SID_NISO0_NVDLA1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:473: iommus = <&smmu_niso1 TEGRA_SID_NISO1_SES_SE0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:488: iommus = <&smmu_niso1 TEGRA_SID_NISO1_SES_SE1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-host1x.dtsi:503: iommus = <&smmu_niso1 TEGRA_SID_NISO1_SES_SE2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-ufshc.dtsi:53: iommus = <&smmu_niso0 TEGRA_SID_NISO0_UFSHC>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mgbe.dtsi:94: iommus = <&smmu_niso0 TEGRA_SID_NISO0_MGBE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mgbe.dtsi:164: iommus = <&smmu_niso0 TEGRA_SID_NISO0_MGBE_VF1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mgbe.dtsi:234: iommus = <&smmu_niso0 TEGRA_SID_NISO0_MGBE_VF2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-mgbe.dtsi:304: iommus = <&smmu_niso0 TEGRA_SID_NISO0_MGBE_VF3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-eqos.dtsi:104: iommus = <&smmu_niso1 TEGRA_SID_NISO1_EQOS>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:325: iommus = <&smmu_niso1 TEGRA_SID_NISO1_BPMP>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:652: iommus = <&smmu_niso1 TEGRA_SID_NISO1_XUSB_DEV>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:717: iommus = <&smmu_niso1 TEGRA_SID_NISO1_XUSB_HOST>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:735: iommus = <&smmu_niso1 TEGRA_SID_NISO1_XUSB_VF0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:753: iommus = <&smmu_niso1 TEGRA_SID_NISO1_XUSB_VF1>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:771: iommus = <&smmu_niso1 TEGRA_SID_NISO1_XUSB_VF2>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:789: iommus = <&smmu_niso1 TEGRA_SID_NISO1_XUSB_VF3>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:1074: iommus = <&smmu_iso TEGRA_SID_ISO_NVDISPLAY>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:1078: iommus = <&smmu_niso0 TEGRA_SID_NISO0_NVDISPLAY>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-base.dtsi:1122: iommus = <&smmu_niso0 TEGRA_SID_NISO0_DCE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-hwpm.dtsi:123: iommus = <&smmu_niso1 TEGRA_SID_NISO1_HWMP_PMA>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:35: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:60: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:85: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:110: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:144: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:167: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:190: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-i2c.dtsi:215: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-gpcdma.dtsi:64: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:34: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:52: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:70: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:88: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:106: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:124: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-uart.dtsi:142: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:13: iommus = <&smmu_niso0 TEGRA_SID_NISO0_APE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:20: iommus = <&smmu_niso0 TEGRA_SID_NISO0_APE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:26: iommus = <&smmu_niso0 TEGRA_SID_NISO0_APE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:129: iommus = <&smmu_niso0 TEGRA_SID_NISO0_APE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:725: iommus = <&smmu_niso0 TEGRA_SID_NISO0_APE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:767: iommus = <&smmu_niso0 TEGRA_SID_NISO0_APE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:775: iommus = <&smmu_niso0 TEGRA_SID_NISO0_HDA>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-audio.dtsi:794: iommus = <&smmu_niso0 TEGRA_SID_NISO0_GPCDMA_0>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-safety-sce.dtsi:61: iommus = <&smmu_niso0 TEGRA_SID_NISO0_SCE>;
./hardware/nvidia/soc/t23x/kernel-dts/tegra234-soc/tegra234-soc-memory.dtsi:645: iommus = <&smmu_niso0 TEGRA_SID_NISO0_SMMU_TEST>;
I used this command “grep -inr --include *.dts --include *.dtsi iommus ./ > dts.log”, searched in your linux kernel in the public_sources.tbz2
@WayneWWW based on Robin’s comments, seems it is possible to achieve SRIOV device assignment, would you please check in the Nvidia, what else I missed?
is this one that used by Xavier board?
seems it is this dtsi, but pcie node status is disabled:
pcie_ep@141a0000 {
compatible = "nvidia,tegra194-pcie-ep";
power-domains = <&bpmp TEGRA194_POWER_DOMAIN_PCIEX8A>;
reg = <0x00 0x141a0000 0x0 0x00020000 /* appl registers (128K) */
0x00 0x3a000000 0x0 0x00040000 /* configuration space (256K) */
0x00 0x3a040000 0x0 0x00040000 /* iATU_DMA reg space (256K) */
0x00 0x3a080000 0x0 0x00040000 /* DBI reg space (256K) */
0x1c 0x00000000 0x4 0x00000000>; /* Address Space (16G) */
reg-names = "appl", "config", "atu_dma", "dbi", "addr_space";
#address-cells = <3>;
#size-cells = <2>;
status = "disabled";
clocks = <&bpmp_clks TEGRA194_CLK_PEX1_CORE_5>;
clock-names = "core";
resets = <&bpmp_resets TEGRA194_RESET_PEX1_CORE_5_APB>,
<&bpmp_resets TEGRA194_RESET_PEX1_CORE_5>;
reset-names = "apb", "core";
interrupts = <0 53 0x04>; /* controller interrupt */
interrupt-names = "intr";
pinctrl-names = "default";
pinctrl-0 = <&pex_rst_c5_in_state>, <&clkreq_c5_bi_dir_state>;
nvidia,max-speed = <4>;
nvidia,bar0-size = <0x100000>; /* 1 MB */
nvidia,device-id = /bits/ 16 <0x1AD4>;
nvidia,controller-id = <&bpmp 0x5>;
num-lanes = <8>;
nvidia,tsa-config = <0x0200b004>;
nvidia,aux-clk-freq = <0x13>;
nvidia,aspm-cmrt = <0x3C>;
nvidia,aspm-pwr-on-t = <0x14>;
nvidia,aspm-l0s-entrance-latency = <0x3>;
nvidia,aspm-l1-entrance-latency = <0x5>;
nvidia,host1x = <&host1x>;
num-ib-windows = <2>;
num-ob-windows = <8>;
nvidia,margin-port-cap = <0x194>;
nvidia,margin-lane-cntrl = <0x198>;
nvidia,cfg-link-cap-l1sub = <0x1c4>;
nvidia,event-cntr-ctrl = <0x1d8>;
nvidia,event-cntr-data = <0x1dc>;
nvidia,dvfs-tbl = < 204000000 204000000 204000000 408000000
204000000 204000000 408000000 666000000
204000000 408000000 666000000 1066000000
408000000 666000000 1066000000 2133000000 >;
dma-coherent;
iommu-map = <0x0 &smmu TEGRA_SID_PCIE5 0x1000>;
iommu-map-mask = <0x0>;
#if TEGRA_IOMMU_DT_VERSION >= DT_VERSION_2
interconnects = <&mc TEGRA194_MEMORY_CLIENT_PCIE5R>,
<&mc TEGRA194_MEMORY_CLIENT_PCIE5W>;
interconnect-names = “dma-mem”, “dma-mem”;
endif
nvidia,bpmp = <&bpmp 5>;
nvidia,aspm-cmrt-us = <60>;
nvidia,aspm-pwr-on-t-us = <20>;
nvidia,aspm-l0s-entrance-latency-us = <3>;
PCIe nodes are enabled in handrware/nvidia/platform//.
Xavier and Orin are not SBSA compliant, so they don’t support PCIe virtualization(passthrough or VF assignment).
Thanks,
Manikanta
Hi @Manikanta
thanks so much for your confirmation, I just read the SBSA, and Orin datasheet,
1.3.5 System MMU and device assignment
Armv8.4 introduces TLB Invalidation instructions which apply to a range of input addresses, instead of just to
a single address.
RS_L3SM_01 If PEs that are used by the base system support TLB range instructions, then all OS visible requesters that
contain a TLB must support range invalidates. See FEAT_TLBIRANGE in [2].
So, since ARMv8,4, there is possible that supports device assignment, however Orin is Arm Cortex-A78AE CPU, and it is based on ARMv8.2, therefore, this board doesn’t support device assignment? Am I correct??
thanks again for your answer,
Orin doesn’t support PCIe device assignment, i.e SMMU doesn’t have capability to used PCIe BDF as SID.
Thanks,
Manikanta
