hi,
i delete sgie2 and test4 runs no error, but only runs few seconds then exit automatically, i will check codes again.
pls help me for dsexample probelm and it is urgently for my project.
another problem is enc_jpeg from nvifer pad on test5:
i got codes which released patch by you from the forums, but when i make that codes, it shows cuda prop error, how should i do?
the part:
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
thank you so much!!!
