Where is tegra_pinctrl_reg in Orin Nano?
Before, I used “/sys/kernel/debug/tegra_pinctrl_reg” in Xavier NX and Nano for knowing register address and value.
But, I can’t find it in Orin Nano.
Please inform about tegra_pinctrl_reg or getting regster address and value.
Thank you.
Hi jtlee,
Please use the following command instead to check the pinmux configuration.
$ sudo cat /sys/kernel/debug/pinctrl/2430000.pinmux/pinconf-groups
What I want to do is changing pinmux through command line.
In Xavier NX, I can changing pinmux using “devmem” command.
For example, if I want to enable aud_mclk that No.7 header of 40-pin header, I just run “sudo busybox devmem 0x02431020 32 0x00000400” in Xavier NX.
But, when I run “sudo cat /sys/kernel/debug/pinctrl/2430000.pinmux/pinconf-groups”, I can’t get register address and value.
How can I changing pinmux in command line?
You could still use devmem to read/write the pinmux register, but you should search for the pinmux register address through TRM document.
