File “tftrt_sample.py”, line 291, in
timings,comp,valfp32,mdstats=timeGraph(getFP32(f.batch_size,wsize),f.batch_size,f.num_loops,
File “tftrt_sample.py”, line 111, in getFP32
trt_graph = trt.create_inference_graph(getResnet50(), [ “resnet_v1_50/predictions/Reshape_1”],
AttributeError: module ‘tensorrt’ has no attribute ‘create_inference_graph’
It seems like that tensorflow.contrib.tensorrt only support TensorRT4.
I’m now using Tensorflow-1.12, which is already the last build of Tensorflow.
**** Failed to initialize TensorRT. This is either because the TensorRT installation path is not in LD_LIBRARY_PATH, or because you do not have it installed. If not installed, please go to https://developer.nvidia.com/tensorrt to download and install TensorRT ****
File "tftrt_sample.py", line 25, in <module>
from tensorflow.contrib import tensorrt as trt
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/tensorrt/__init__.py", line 34, in <module>
raise e
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/tensorrt/__init__.py", line 25, in <module>
from tensorflow.contrib.tensorrt.python import *
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/tensorrt/python/__init__.py", line 22, in <module>
from tensorflow.contrib.tensorrt.python.ops import trt_engine_op
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/tensorrt/python/ops/trt_engine_op.py", line 32, in <module>
resource_loader.get_path_to_datafile("_trt_engine_op.so"))
File "/usr/local/lib/python3.5/dist-packages/tensorflow/contrib/util/loader.py", line 56, in load_op_library
ret = load_library.load_op_library(path)
File "/usr/local/lib/python3.5/dist-packages/tensorflow/python/framework/load_library.py", line 60, in load_op_library
lib_handle = py_tf.TF_LoadLibrary(library_filename)
tensorflow.python.framework.errors_impl.NotFoundError: libnvinfer.so.4: cannot open shared object file: No such file or directory
