Hi:
we have a customized board,the EDP interface is ok,but when I “dmesg”,I found:
[ 21.408728] vdd_ds_1v8 regulator get failed
[ 21.408730] edp regulator get failed
WayneWWW says "just comment out those regulator checks in edp panel driver if you don't need it",but I could not found the "board-panel.c",<b>so where is the default edp panel driver in tx2 </b>?
XuXiang,
panel-a-edp-1080p-14-0.c is what you are looking for.
board-panel.c is for tx1 only. On tx2, those panel selection codes are under nvdisp_stub.c
but,where is “nvdisp_stub.c” ?
find -name “nvdisp_stub.c” ,get nothing.
It should be under kernel/t18x/driver/videos/tegra/dc/nvdisp
I get it!
It’s under kernel/… ,not kernel/kernel-4.4 !
Thank you very much!!!
