Where is the Isaac ROS CLI Github Repo?
In the latest update for isaac_ros_common, the docker dev container code was moved to a new repo named Isaac ROS CLI. But the link provided to that repo is giving a 404.
Here’s the documentation with the link. Look at the latest entry in Updates…
And here’s the broken link…
https://github.com/NVIDIA-ISAAC-ROS/isaac-ros-cli
I’m just trying to find where the docker dev container code went.
Thank you,
Hello @brettpac,
Welcome to the forum and thank you for raising this issue!
You are correct, the GitHub repository link was published in the documentation before the source code was made publicly available. We apologize for the inconvenience.
The Isaac ROS CLI source code has now been formally released. You can try checking the repository again at the following link: Isaac ROS CLI
