hi,
I have flash the AGX Xavier through the sdkmanager successfully,but i can’t find the script jetson_clocks.sh.It seems that there’s a big difference with the factory os.
Hi sunzhongmeng,
It is now an executable located at:
/usr/bin/jetson_clocks
thanks,i got it!
Besides I can’t shutdown the Xavier used :sudo shutdown -r now.
the Xavier will be reboot!
-r is for reboot. Don’t use it if you want to power off. You can also use sudo poweroff.
