NVIDIA Tegra Linux Driver Package Development Guide(32.2 Release) mentions that,
“The CDF is provided at:
/vendor/nvidia/tegra/bootloader/partner/common/
/vendor/nvidia/tegra/bootloader/partner/t18x/common/”
But I can’t find it, cause there are no these directory tree. And the Guide also say “MB1, TegraBoot-BPMP, and TegraBoot-CPU/C‑Boot each needs to use one of several drivers” belong to CDF. So the CDF should be flashed into eMMC in an very early time, yet no relative information can I find.
They are just lots of drivers. Not sure what you are looking for.
All the drivers under partner/common/ and partner/t18x/common/ are the CDF.
Thank you.
Actually, I can’t find them in l4t32.2 including kernel source code, u-boot source code, rootfs.
garret:~/tx2/l4t32.2$ sudo find ./ -type d | grep "t18x\/common"
./sources/hardware/nvidia/platform/t18x/common
./sources/hardware/nvidia/platform/t18x/common/kernel-dts
./sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-prod
./sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-modules
./sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms
./sources/hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-plugin-manager
garret:~/tx2/l4t32.2$ sudo find ./ -type d | grep "partner"
./rootfs/usr/share/doc/app-install-data-partner
Yes, because rel-32 cboot source is not released.
Thank you.
How can I get cboot source code?
Sorry for my mistake. Rel-32 cboot source is released on the download center. Please check the source code. (but not yet released for Nano and TX1)
