Where should final actuator safety authority reside in a Physical AI system?
Hello — I have one non-confidential architecture question about functional safety for Physical AI systems.
In a system where an AI agent or higher-level planner has already passed software-level identity, authorization, and policy checks, what component in the recommended NVIDIA safety architecture should ultimately have authority to permit or prevent a consequential actuator action?
More specifically, does the safety architecture assume that protected physical effects pass through an independently enforceable safety boundary, or can the final action constraint remain within the application/runtime software layer depending on the system design?
I’m trying to understand where NVIDIA considers the final safety authority boundary to belong, rather than whether hardware or software is generally “safer.”
Hi sdh_own,
A concise way to think about it is this: for consequential actuator actions, the final permit/block decision should sit in a safety-related control path with independent enforceability, not only in the general application or runtime layer.
Higher-level AI, planning, and policy software can propose or qualify actions, but the final authority for protected physical effects should remain in the safety boundary. The exact implementation can vary by system architecture, but the recommended pattern is that the last safety gate is independent of the nominal application path.
