I’m running some python code that I did not write myself. I’m running one classifier, which gives each of its three classes one probability. I want to access all of these probabilities and I read that I need to change output_tensor_meta to true in the file “dstest_ssd_nopostprocess.txt”. But I can not find this file at all. What am I doing wrong? Is there any other way to access the probabilities? Or any documentation with full information on how to do this?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
