Q1. Whether there is a module capable of outputting 3840 x 2400 resolution from Jetson modules (TX2, Xavier, Orin, etc.)
Q2. Whether you can use the Jetson module to split one image across multiple monitors, such as a video wall display, or display a different image on each monitor
The resolution of the exhibition monitor is 1920x1200
For Q1, Orin might be able to output this resolution. Actually, you can try it on Xavier too but hacking the driver is needed. Also, it is just experimental try. I don’t guarantee it would 100% woirk.
For Q2, Yes, it is feasible. This is not related to kernel driver. This is done by userspace graphic applications. We have gstreamer pipeline and MMAPI sample to demo those functionality.
