Whether ramdisk is supported on jetson-nano?
Hi:
I tried to modify the initrd on jetson-nano emmc, it’s not effect, The steps are as follows:
What “no effect” ?
Hi:
I tried to remove the “INITRD /boot/initrd” on extlinux.conf but the rootfs also can be load on mmcblk0p1.
You can dump the uart log and see what is going on.
yes I find if I remove the line, the kernel will load the default init process on mmcblk0p1, but if I modify the initrd, the initrd is also can been effect.
