Hi Experts,
I download Jetson_Linux_r36.4.3_aarch64.tbz2 from link https://developer.nvidia.com/downloads/embedded/l4t/r36_release_v4.3/release/Jetson_Linux_r36.4.3_aarch64.tbz2
and then uncompress it. In directory Linux_for_Tegra/bootloader, I don’t find out the bl31.bin.
But in below link, It mentions that there is ATF loaded during boot flow.
Jetson AGX Orin, Orin NX and Orin Nano Boot Flow — NVIDIA Jetson Linux Developer Guide
So, I am a little confused, could you please help to explain that, and where I can get the ATF binary file?
thanks,
LImeng
you need to download public sources tar file and inside that you can find sources for ATF etc.
Op-tee sources are available in nvidia-jetson-optee-source.tbz2
Atf_src.tbz2
hello meng.li,
in general, we’ll extract atf_src.tbz2
and nvidia-jetson-optee-source.tbz2
to the same folder, such as.. atf_and_optee/
there’s readme file, atf_and_optee_README.txt , as you can see, bl31.bin
is used to generate the TOS image.
Thanks for all of your reply.
Regards,
Limeng
system
Closed
April 23, 2025, 3:02am
7
